Author Topic: Benson vertical steam engine.  (Read 1676 times)
« on: May 31, 2021, 03:07:37 PM »
Well the Benson is finished. I just have to make a wood base to mount it on. The governor didn't have enough weight to return to the rest position even though I made sure everything moved freely so I added a spring made from .008 wire and wound around a .062 mandrel. I had to keep stretching it until I got just the right pressure for it to work and return. I will post a video as soon as I get it. Everywhere there was bolts I replicated studs with nuts by leaving a small projection beyond the hex. The build log is under 'Engines from Drawings'.
Re: Benson vertical steam engine.
« Reply #1 on: May 31, 2021, 03:12:43 PM »
Beautifully done!  :NotWorthy:
« Reply #2 on: May 31, 2021, 03:23:16 PM »
What a jewel-like engine. Just a pleasure to look at!
Offline propforward
  • MN, USA
« Reply #3 on: May 31, 2021, 03:25:36 PM »
Art, craftsmanship and engineering all in perfect harmony in that engine.
Forging ahead regardless.
Offline pgp001
  • West Yorkshire - UK
« Reply #4 on: May 31, 2021, 03:44:48 PM »
Did you make the dummy studs/nuts from scratch, or are they modified off the shelf bolts ?
I have a load to make for Agnes and have just set up the capstan attachment on my Pultra to make them.
Super engine by the way.
Phil
Offline simplyloco
« Reply #5 on: May 31, 2021, 05:03:20 PM »
Very pretty!
Strong minds discuss ideas, average minds discuss events, weak minds discuss people.” ― Socrates
« Reply #6 on: May 31, 2021, 05:53:41 PM »
That's a beautiful engine, George!
« Reply #7 on: May 31, 2021, 06:41:25 PM »
Hi Phil,
I made most of the nuts and bolts with taps and dies, even down to M1.0 x .25. Most full sized engines had studs and nuts but for this scale duplicating them while doable is just not my cup of tea. I turn and thread the shank of the bolt then put it in the dividing head to create the hex. It then goes back to the lathe and I cut a short projection the same diameter as the screw size and then cut it off. It looks like a stud poking out of the hex but in fact is just a representation.
Offline pgp001
« Reply #8 on: May 31, 2021, 11:06:15 PM »
I am doing almost the same apart from using hexagon bar stock to save milling all the flats, I am using a lot of M1.6 stud/bolts and have a thread roller for that size rather than cutting with a die.
On the Pultra capstan attachment it is a a fairly slick operation to make these, it just takes a while to set it all up.
Phil
« Reply #9 on: May 31, 2021, 11:35:55 PM »
George my friend that is absolutely stunning. Your still my hero buddy. But I think it would look better polished so you will have to send it to me to polish for you…….awesome work my friend… :Love:
Offline gldavison
  • Tarkio, Mo.
« Reply #10 on: June 01, 2021, 01:51:48 AM »
Beautiful  :cartwheel:   Fantastic   :pinkelephant:  Aw some   :whoohoo: :cheers:
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline kuhncw
« Reply #11 on: June 01, 2021, 02:35:53 AM »
Very nice, George.
Chuck
« Reply #12 on: June 01, 2021, 12:50:18 PM »
Hi George, thanks for posting another exquisite build.
I have just spent the afternoon making some M2.5 nuts which gives me an even closer appreciation on your M1 examples.
Offline gary.a.ayres
« Reply #13 on: June 06, 2021, 11:06:09 PM »
Very beautiful!
Offline Camm-1
  • Sweden
« Reply #14 on: June 07, 2021, 05:26:53 PM »
Super nice as usual!
Skickat från min M2004J19C via Tapatalk
