Les Chenery published a design for one as did Stephen Wessel for a 9cyl, Guy on HMEM possibly going to do some castings for the Chenery crankcase if anyone fancies a go.
The Chenery one only had one casting for the crankcase which could probably be hacked from solid. The other design just had the crankcase done in steel with the cylinder bases silver soldered to a ring. So as you say ideal for those that like doing it that way, Should keep you out of mischief once the beam is finished
John - Having built a 1/4 scale Mono from Stephen Wessel's 1/3 scale drawings I can vouch for the quality, accuracy and completeness of his drawings. They are a work of art and with the engine being fabricated from steel (for the most part) has a very nice, prototypical appearance. Well worth a look if you are interested in a Monosoupape.Charlie
Hi John, There’s a guy here in NZ who was building one, I saw the parts back in the 80’s. I haven’t seen him for some time so not sure we’re he is with it. He had done a lot of research into it prior to & during the building. I hope he finished it as he was a great machinist. SNIPCheers Kerrin
Thanks DaveKerrin - here is a link to a brief video of it running. I was messing about with the fuel control (a variable speed fuel pump supplying the crankcase line). It settled into a nice run just before running out of fuel - the whining at the end is the 'dry' fuel pump.
