I left the crankshaft with the first side rough turned circular so it is time to finish off the turning. This end I am going to turn to dimension (the other end is still over sized). I initially turned it using the same roughing (second hand tip) then swapped over to a new stainless steel cutting tip which gave an acceptable finish.
With the shaft 0.5mm over diameter it is then time to take down the faces of the crank web:
There was nearly 3mm that needed to come off. How I worked this out was: I knew the overall width I was aiming for (25.4mm), I knew what the width actually measured 31mm, I could measure the gap in the middle and I knew what thickness I needed for each web (6.35mm). At this point I am ignoring the inner gap dimension in so far as I need to leave enough so that each web can actually be 6.35mm thick (easily done if you take too much off one side
Having faced one side to where I had decided that face should be it was time to do the final cut on the diameter of the crank shaft before turning round and repeating: take diameter slightly over sized, do face, then take to final diameter. If you take the diameter down to the correct diameter before doing the face you are likely to end up with ridges alongside the webs
Now for the crank pin:
I have mounted the crank in my crankshaft turning jig, you could probably use a 4 jaw to do the same. What you should watch is that ideally you want to hold the crankshaft next to the web to minimise the amount of flex (I learnt all about crankshafts flexing when I did my triple cranks
) As you can see I have made up a crank support that has one hole the diameter of the crankshaft and a centre drill spaced at the throw of the crankshaft - this was used to position the crankshaft on the face plate and secure it as well as a support for use during turning.
You need a long parting off tool to turn the crankpin: One that won't be hit by the webs as they spin round. Always check everything is well clear before turning the power on - you never know what may hit on these types of turning jobs. Now we are going to start by cutting either side square:
With both sides just over thickness the central pin can be turned. Note that you should "plunge" the cut nearest the left hand side and turn the material off towards the right - this is because there is less likelihood of any flexing nearer the holding jig/chuck.
Then carefully you can take the pin down to diameter - remember as the diameter reduces the greater the chance the crank will flex. This means you may need to reduce your cutting depth to avoid flexing which will end in
failure. In the end the crank is down to diameter and we can take a final skim off of each web which brings them to thickness:
and now we can have a look at the crankshaft in the soleplate casting:
Before squaring off the throws I need to have a look at the crank balance weights.
