Author Topic: Solid Fuel Tablet Sizes  (Read 552 times)
Offline Johnmcc69
  • Erie Pa., USA
« on: April 17, 2021, 04:30:41 PM »
I'm designing a burner tray for my "Dribbler" loco & was wondering if someone could give me the sizes of the "Solid Fuel" (Esbit, Meta", other) tablets that are available (Length, width, height).
A quick look at the Esbit website shows me 3 sizes available: 14, 5, & 4 grams, but no dim's/sizes.
Online propforward
  • MN, USA
Re: Solid Fuel Tablet Sizes
« Reply #1 on: April 17, 2021, 05:37:44 PM »
The Esbit 4g tablets measure 1/2" X 1/4" X 1-5/16"
I've also got some Mamod brand tablets that measure 7/8" DIA X 13/32" thick.
Give or take. This measurement was steel rule based. I didn't feel like breaking out my micrometer for this. :D
These are the only tablets I have on hand.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #2 on: April 17, 2021, 11:29:55 PM »
 Aw nuts Stuart. I should have mentioned I need the METRIC version of the tablets. I'm designing it all in metric...waaaay to far ahead in my design to start over for the "imperial" size tablets.  :toilet_claw:
 jOhN
 (Thanks Stuart  :cheers: !)
« Reply #3 on: April 17, 2021, 11:36:30 PM »
There are no metric vs imperial versions of the tablets. Stuart just used an inch ruler on his. Easy conversion to mm.
Online propforward
  • MN, USA
« Reply #4 on: April 17, 2021, 11:43:35 PM »
 jOhN
Not a problem! Iíll make a holding fixture, and face mill each tablet to size!
 :lolb:
« Reply #5 on: April 17, 2021, 11:48:16 PM »
I have some labelled Outback Solid Fuel Tablets.  About 22 mm dia by 13 mm high cylinders, though I often sit them on edge to burn.  Close enough to the same size as Stewartís.
You can also break up the rectangular ones sold as firefighters.
« Reply #6 on: April 17, 2021, 11:50:54 PM »
Fire Lighters? Not good as a firefighter!  :hellno:
« Last Edit: April 17, 2021, 11:54:06 PM by crueby »
« Reply #7 on: April 18, 2021, 02:25:29 AM »
Youíre right, but they are great for getting the back yard charcoal bar-b-que going, or the living room fireplace, saves cutting kindling.
Not bad for the campfire either, particularly if itís been a bit wet.  And a lot safer than a bit of kerosene, we used to use in scouting days!
Offline Pete49
« Reply #8 on: April 18, 2021, 04:14:14 AM »
You sooky la la  :LittleDevil: when I was in the scouts we used petrol....guaranteed to lit wet logs and sleeping bags.
I used to have a friend.....but the rope broke and he ran away :(
Offline Zephyrin
  • near Paris, France
« Reply #9 on: April 18, 2021, 09:05:21 AM »
 Hi John,
33.5 x 13.5 x 7.5 mm for the esbit tablet I have, almost all broken in parts, like biscotte in their packet.
But you probably need two for a efficient steam production...
It is useful for a short demo, but really stinks.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #10 on: April 18, 2021, 01:18:43 PM »
 :LittleDevil: Yes, I know that Chris, just having a little fun with Stuart.
 You've been spending too much time in the shop....
Online propforward
  • MN, USA
« Reply #11 on: April 18, 2021, 01:35:50 PM »
 :thinking:
Is there such a thing as too much time in the shoppe?
« Reply #12 on: April 18, 2021, 01:38:21 PM »
:thinking:
If it takes away from time in the boat, yes!
Online propforward
  • MN, USA
« Reply #13 on: April 18, 2021, 01:49:31 PM »
Ah yes! Excellent point.
For me itís the sidecar rig, but same idea.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #14 on: April 19, 2021, 11:43:33 PM »
Thank you very much gent's!
 I've (You) filled in the last piece of the puzzle.
 I already had some of the sizes "roughly" figured out, these constraints in the design was something I had already planned on.
 The original design (From info gathered here & from pictures), the firebox somehow "magically" just snapped into place...I didn't much care for that & designed a more "secure" method. (You'll see the completed design posted here in awhile...) I'm pretty happy how it turned out.
 I designed it so the engine can run on "Meths" as original in a lower tray, with whatever the builder might prefer...still unclear about what was used as a "wick" & it appears that there was a screen..-feel free to chime in on preferred methods, I can still add it to my drawings.
 But..I think the solid fuel tablets might be the way to go so I was able to incorporate the burner tray for that into my existing design. I like that better. I can fit (2) of the 4 gram tablets side by side in the burner. The Esbit 4 gram tab's are supposed to burn for like, 4-5 minutes, so I think I can get that to work. (Of course some of you will inquire further into the volume of water that is needed to heat ETC., boiler wall thickness..global shift & what Chris's next project will be...)
 It's a TOY. Originally meant to run around on the floor of your house. It'll make a really nice display model.
 ...I digress.
 Have a look at the original burner pic & my plans for what I would like to do.
 Please, let me know your thoughts...
 See link. As big as the internet is & the big "Cloud" they always yap about, my files are too large to be posted. & I'll probably screw that up as well.
https://drive.google.com/drive/folders/1z_H4Ui5NcY7kzVI2PHVjwdjwvBGDj-Cs?usp=sharing
 Re: "Shop Time"- Yep. It's "kinda" like spring here in NW PA. Already been camping, mowed the lawn (might be blowing snow in a couple days), the trout fishing is good, be biking soon, (motor & MTN.) clean up the kayak...never enough time.
