Author Topic: New Mills Pumping Station  (Read 56160 times)
Re: New Mills Pumping Station
« Reply #525 on: March 17, 2023, 12:49:56 AM »
Back to the model and I have painted the turbine with undercoat and top coat... I am also going to make a circular perspex drum to surround the top part of the turbine to deflect the air to the blades in a better more efficient manner. Air has only 1/8 the force of water at the same pressure so I can use a smaller compressor ??!! so we shall see if this works ...The perspex block is bolted to the faceplate ready to turn to size.
Willy
« Reply #526 on: March 18, 2023, 02:29:30 PM »
Thank you for posting the pictures of the show  :ThumbsUp:  :ThumbsUp: Lots of fine and interesting exhibits  :)  :)
« Reply #527 on: March 24, 2023, 02:46:04 AM »
More work with the Turbine air inlet cover.  the main part is turned up whilst bolted to the faceplate ,..however I need to turn up the other side so I have made another perspex plate to use as a temporary cover to hold the assy stable using a revolving centre to turn the unit safely in position ...  still more final fitting  and also drilling the air intake nozzle orifice ??!!
Willy
« Reply #528 on: March 24, 2023, 03:04:39 AM »
so a few more pics ...removing some of the material with a 32tpi hacksaw  and fitting the unit with more hand filling to get the correct depth
willy
« Reply #529 on: March 25, 2023, 02:09:44 AM »
The air tight cover is now completed and the model reassembled . The inlet hole has been drilled and an air pressure test is imminent !!!
Willy
« Last Edit: March 25, 2023, 02:31:55 AM by steam guy willy »
« Reply #530 on: March 25, 2023, 02:14:20 AM »
Hisssss... whirrrr!     :popcorn: :popcorn:
« Reply #531 on: April 07, 2023, 12:34:28 AM »
Thanks Chris , I have been busy doing the editing of the local NOG magazine  and also been busy in the allotment  but will be back in the WKSP soon
Cheers............
« Reply #532 on: April 11, 2023, 01:22:44 AM »
So Back in the wksp and the air compressor is still not operating the turbine ... however I was taking a Microwave cooker apart to remove the two big magnets and found the bowl rotating motor  This is 240 volts and rotates very slowly. I had it connected and found the torque at this slow speed was quite phenomenal. So I am thinking of using this to rotate the model ...I have a large quantity of gears ,sprockets  chain down about 3/16th link size and have made a drive to see how it will work out ??
 more news tomorrow ....
Offline Zephyrin
  • near Paris, France
« Reply #533 on: April 11, 2023, 07:33:52 AM »
very nice basement for your steam engine and its mechanics!
you are also an expert in machining perspex, so easy to ruin a hole with a drill bit that gets a little too hot...
« Reply #534 on: April 11, 2023, 09:51:27 PM »
Hi Zeph,  Thanks and I am just lucky I think as there are different types if perspex and acrylic so I may be just lucky ...also I do drill a lot of my holes with hand tools that are much slower ??
Willy
« Reply #535 on: April 12, 2023, 02:08:37 AM »
I have now made the motor support bracket and turned and milled from a large piece or perspex...I now need to adjust the chain length and then bolt everything back in place and see what happens ? !!
Willy
« Reply #536 on: April 12, 2023, 02:54:21 AM »
I like the idea of the chain drive. It reminds me of model engines I've seen in museums, set up to run when visitors  push a button.
 :popcorn: :popcorn:
« Reply #537 on: April 13, 2023, 12:25:32 AM »
Not a valid vimeo URL.      Here is the video of the compressor plant with the electric motorised system working it
So lots more work to finally finish it www.Not a valid vimeo URL So  I cannot seem to attach the video ???   <iframe title="vimeo-player" src="https://player.vimeo.com/video/817096561?h=1336f0c84c" width="640" height="360" frameborder="0"    allowfullscreen></iframe>
Willy
« Last Edit: April 13, 2023, 12:58:19 AM by steam guy willy »
« Reply #538 on: April 13, 2023, 10:29:59 AM »
So now it is ready for future displays @ Shows  :ThumbsUp:
Any plans for the next project Willy ?
Per           :cheers:
« Reply #539 on: April 13, 2023, 12:47:39 PM »
Great to see it all in action!
