Author Topic: New Mills Pumping Station  (Read 55933 times)
Re: New Mills Pumping Station
« Reply #390 on: July 01, 2022, 12:10:53 AM »
hi Roger ...yes of course..
willy
« Reply #391 on: August 06, 2022, 01:31:21 AM »
Hi , I am now back in the workshop after being very busy on the allotment getting a tan and editing the local Organic group newsletter !! also catching up with lots of household jobs ..also trying to cope with all this hot weather and visiting Museums and other summer stuff...... so... watch this space ...
Willy
« Reply #392 on: August 06, 2022, 01:44:52 AM »
Excellent, sounds like a busy and hopefully fun summer. Getting more popcorn ready...
« Reply #393 on: August 08, 2022, 02:34:00 AM »
Hi "C" , thanks and there will be fine hot weather to come .. I have acquired some aluminium to make the base  and there were originally steam engines included on this ..however they have long gone. there are still  mock ups of what they might've looked like .  It looks as though the configuration was a tandem compound ??...However the only photo I have shows just I cylinder ??
Willy
« Last Edit: August 08, 2022, 02:57:17 AM by steam guy willy »
« Reply #394 on: August 11, 2022, 03:33:01 AM »
The aluminium base plate has beensawnoff the slab and after centering the vice the sawn edge is milled down to size...the next step in to mark it out for shaping up ...
Willy
« Reply #395 on: August 11, 2022, 12:46:47 PM »
Hi Willy, good to see you back making progress again.  Glad to find that you were gainfully occupied over the summer.
Is it possible that the two cylinders you were showing in the previous post were a steam cylinder in tandem with a compressor cylinder?
And did you work out the valve arrangement in the compressor cylinder?
« Reply #396 on: August 16, 2022, 12:38:08 PM »
Hi MJM, surviving the latest heatwave at the moment . Will be back in the WKSP soon hopefully....
Willy
« Reply #397 on: August 17, 2022, 02:41:12 AM »
So ready to mark out and machine the aluminium base plate...
Willy
« Reply #398 on: August 18, 2022, 03:05:53 AM »
The base has now had the outside profile milled ,,,first with an end mill to reduce the bulk of the metal and then finished with the Ball endmill.
Willy
« Reply #399 on: August 19, 2022, 02:10:59 AM »
The recess for the crank is now drilled out by chain drilling and then sawn out with the abrafile Hacksaw. the slots for the bearing adjustments are milled out ready to fit the stops that would have been part of the casting . The Hacksaw is an old  "Eclipse" No 60B with the abrafile notch parts .
Willy.
« Reply #400 on: August 19, 2022, 07:42:39 PM »
It is good to see progress on this thread again Willy  :ThumbsUp:   :cheers:
« Reply #401 on: August 20, 2022, 11:49:35 AM »
Thanks Per , and good to be back in the WKSP.....
"W"
« Reply #402 on: August 23, 2022, 02:45:19 AM »
The base plate buffers for the main bearings are being made from brass and they are bolted in place. they will also be held in place as they protrude under the bearings and will be held down firmly when they are bolted in place.
« Reply #403 on: August 24, 2022, 02:04:58 AM »
The other buffer stops are now in position but there is more profiling to do ....
Willy
« Reply #404 on: August 24, 2022, 02:39:42 AM »
Excellent, really coming together...    :popcorn: :popcorn:
