Author Topic: New Mills Pumping Station  (Read 56129 times)
Re: New Mills Pumping Station
« Reply #465 on: November 30, 2022, 12:30:23 AM »
hi all ,and thanks for the comments and encouragement ... the painting has now begun on the finished items ready for the correct nuts and bolts...
Willy
Offline scc
  • Lancashire, UK
« Reply #466 on: November 30, 2022, 09:47:06 PM »
Impresive work Willy,  especially on the tiny fasteners. :ThumbsUp:                     Terry
« Reply #467 on: December 02, 2022, 01:57:52 AM »
Thanks Terry , Yes those fasteners are very fiddly and I
allways sweep my floor and have a long magnetic pole to pick them up off the floor !!  So coming together slowly and you just can't rush the painting ...
Willy
« Reply #468 on: December 06, 2022, 02:19:58 AM »
So more work  and getting the parts assembled ..but ..still more fitting and painting to do...
Willy
« Reply #469 on: December 06, 2022, 02:27:08 AM »
Hi Willy. Great to see all those parts finally coming together in one place! :cheers:
« Reply #470 on: December 06, 2022, 02:44:25 AM »
Great!   :popcorn: :popcorn:
Online steamer
« Reply #471 on: December 06, 2022, 03:04:51 AM »
Love the style of this engine.   Old English steam has class all its own     watching along!
« Reply #472 on: December 12, 2022, 01:55:16 AM »
Hi Everyone ...thanks for the comments and I have been doing more painting ..As most of the parts are made from brass I have been using some acid etch undercoats as well as several coats of paint. Here are more photos ,...but still more work to do..
« Reply #473 on: December 22, 2022, 01:49:34 AM »
The stanchion for the gate adjustment has been made ...This is for stopping the turbine from rotating to facilitate maintenance.with the machinery.  more cleaning up to do but getting there...
Willy
« Reply #474 on: December 22, 2022, 02:05:04 AM »
Still enjoying following along, Willy.  :ThumbsUp: :cheers:
« Reply #475 on: December 22, 2022, 02:22:23 AM »
Great proportions!   :popcorn: :popcorn:
« Reply #476 on: December 29, 2022, 02:05:46 AM »
I have now filed the Handwheel for the turbine adjustments ... and made this fixture to hold it in the vice to make it easier to file the casting to shape ....also I have these Valorbe files that come in many shapes and sizes...however they are quite tricky to hold with the sharp ends  so I cut them in half and use a handle !! Thanks for the comments and I am making a different compressor connection that actually works !!
Willy
« Reply #477 on: December 31, 2022, 01:12:25 AM »
New Mills model now working with a better compressor
<iframe src="https://player.vimeo.com/video/785316774?h=ef4324be90" width="640" height="360" frameborder="0" allow="autoplay; fullscreen; picture-in-picture" allowfullscreen></iframe>
<p><a href="Not a valid vimeo URL">New Mills air pumping station</a> from <a href="https://vimeo.com/user44309902">robert Bailey</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
I now need to make the new housing for the turbine and engine parts to display the finished model and also finish all the correct small parts ..
Willy
« Last Edit: December 31, 2022, 01:21:36 AM by steam guy willy »
« Reply #478 on: December 31, 2022, 01:40:09 AM »
Here are some photos of the engine as it is at the moment in the pumping station building ...unfortunatly the original steam engine were removed in the 20 when they electrified the station in the 20's. This is why there is the empty space left I place on the longer bedplate . If I can find some more older photos/drawings of the original set up then I could finish the components  !!
Willy
Offline vtsteam
« Reply #479 on: December 31, 2022, 02:41:50 AM »
It looks great Willy!!!  :ThumbsUp: :ThumbsUp: :ThumbsUp:  :cheers:
