Help! > Machines, Tools and Fixtures
How many axes on a lathe DRO?
Jo:
If you already have a 2 axis DRO then upgrading to 3 axis is expensive as the Display also needs to be upgraded (it automatically combines top slide and saddle)
If you don't have DROs on your lathe... :headscratch:
Daggers:
I fitted a dro kit to my Myford last year it came with 2 axis scales but used a 3 axis dro so later i could update with a third scale if needed.
What i liked about this kit was that the cross slide scale is hidden under the surface. It did require a groove in the cross slide base, but this was a very simple job.
crueby:
--- Quote from: Jo on March 16, 2021, 11:50:36 AM ---If you don't have DROs on your lathe... :headscratch:
--- End quote ---
then, I wouldn't be able to make complicated engines like this... Oh - wait, yes I can, and do!
Just means I have to take a direct measurement a little more often and count on the handwheels. :shrug:
Jo:
--- Quote from: crueby on March 16, 2021, 01:17:54 PM ---Just means I have to take a direct measurement a little more often and count on the handwheels. :shrug:
--- End quote ---
Yup ;)
And don't forget to wear the glasses :DrinkPint:
propforward:
To be honest all I really "need" is a bit more resolution on the carriage. It's not like I can't hit dimensions accurately, but whereas it is quite simple to hit within a thou on diameters, turning lengths is trickier. Similarly I'd like some more accuracy on the tailstock. That could actually be achieved by adding a manual vernier scale (for example).
After all this if I do add DRO's I'll likely just make it a 2 scale job, and maybe a single standalone scale on the tailstock.
Interesting to read perspectives. Thanks everyone for your input.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
