Author Topic: Chris's Holly Pumping Engine Build  (Read 155601 times)
« Reply #1230 on: September 23, 2021, 10:47:49 PM »
finished up the flattening step on the upper crosshead pieces
makes a good start on the 'kits'
« Reply #1231 on: September 23, 2021, 10:58:38 PM »
Oh yeah! I seen some more silver soldering here waiting to see the final results.    :Love:
« Reply #1232 on: September 24, 2021, 12:57:07 AM »
You see clearly Don!  These first pieces will have matching recesses cut into the center bar, and the end bars (the brass ones) will be cut to fit around the center bars, and all four parts will be silver soldered together. Then I'll have the equivalent of the casting the real one was probably made with.
 :cheers: :cheers: (one from me, one from the elves! )
« Reply #1233 on: September 24, 2021, 03:59:59 PM »
Some time on the lathe this morning, got the blanks for the horizontal parts of the crosshead turned to diameter and length, with a step in each end. Also cut off the upper pieces from the bars they were held with and trimmed them to length:
Next step is to cut the recess in the side of the cross pieces to take the bottom of the upper pieces. I'll do this on the lathe, with them held in the 4-jaw. Here is how it will be held, and the way the pieces will fit together once the recess is turned in:
Going to take a little time with the indicator to get the bar centered up, good project for this afternoon...
« Reply #1234 on: September 24, 2021, 05:41:26 PM »
After lunch got the recesses turned in, and also drilled/tapped a center hole. The hole will serve two purposes - a way to hold the upper piece in place for soldering and provide a reference point later on when milling out the center of the cross bar.
Here are the parts so far
Next step will be to cut the semicircles in the brass bars to fit over the ends of the cross bars
« Reply #1235 on: September 24, 2021, 07:07:22 PM »
Great progress on the crossheads, Chris!  Those are complex little buggers for sure!   :popcorn: :popcorn:
« Reply #1236 on: September 24, 2021, 07:37:05 PM »
Thanks Kim.
If they dont work for the crossheads, I can make a really complicated door hinge!
« Reply #1237 on: September 24, 2021, 08:58:51 PM »
After some casting about (bar stock pun there) with the vises, different chucks, etc trying to figure out how to hold the brass bars to bore the off-center and out-the-side holes, I hit on using the faceplate. The hole needed is slightly smaller than the hole in the faceplate, and I found a plate that had two holes in the right place already, just needed one more drilled/tapped to hold it like this for boring:
Worked perfect
One down, 5 more to bore out. The starter hole was done with a center drill, then worked in the boring bar a layer at a time.
« Reply #1238 on: September 25, 2021, 12:30:36 AM »
« Reply #1239 on: September 25, 2021, 12:55:19 AM »
That is a really cool looking part. Maybe you should make an extra just to put on the shelf. I'm sure you could make up all kinds of stories to tell people when they ask what it is. ;)
« Reply #1240 on: September 25, 2021, 01:14:15 AM »
Yep your the man Dog……. :Love:
« Reply #1241 on: September 25, 2021, 01:16:27 AM »
Lets see...
It's the key to my Tardis
New drive shaft for a Ferrari
Chandelier for the shop elves
It fell off the rocket from the last Apollo launch
Its the wind up key for my robot
« Reply #1242 on: September 25, 2021, 01:17:25 AM »
Thanks Don,  what time will you be here for the silver soldering?
« Reply #1243 on: September 25, 2021, 10:30:11 AM »
Hi Chris, a lot of progress every week. Nice to see it all coming together step by step.
« Reply #1244 on: September 25, 2021, 02:07:18 PM »
Great to have you along for the journey Achim!
