Nice find thanks to the gent who found it. Speaking of hot bearings on vintage large engines.... well the only way to detect the bearing temperature on the engine was to touch the bearing!!! Notice the missing paint on the vertical rail support near the main bearing, just where you would hang on to touch the bearing.The big end bearing of the conrod was checked by touching it as it passed by to check for a hot bearing. Needless to say, this was somewhat dangerous and more than one engineer was missing a finger or two.Cheers Dan
A long process for these frames.
QuoteA long process for these frames.To badly paraphrase a well known aphorism - You're about to see the light at the top of the tower! Then you can take pride in another job well done and a big step forward in the larger job.
Chris you mention that you are almost ready for painting those - but I must admit that I thought that the guide part in the middle should be worked on in the mill to ensure a flat even surface on those ...?Per
