Looks like a great show! Lots of interesting old goodies. I like the dump truck just as much as the steam shovel!
Great steam show pics! Thanks for posting them. TWO Corliss engines at one show! Never seen an oil burner on a boat's VFT boiler before - but a nifty idea. Cleaner than coal and safer than propane - and smells like the inside of a Kenworth engine's injector pump. The low slung Eclipse / Frick engine was nice to see. I used to see a few here in Ontario, but not in the last couple of years. You know I've looked and looked at them and never saw any "e" clips at all, not sure why they are called Eclipse.... Terrific progress on the Holly frame details and brackets!
Thanks for the pics of the steam show. That looks pretty cool.So, they just turned the shovels loose in a field and let them dig holes all over? That's pretty amazing. Did they have to put the dirt back when they were done?Kim
It's always good to see those old engines working and doing what they are supposed to. The annual steam threshers reunion at Rollag is coming up soon - might get along to that.Your build continues to impress as always Chris!
Chris, very interesting feature. The brass bearing for the crankpin has square flanges and is octagonal in the center section, this is how I read the dotted lines indicated by the blue arrows.Is this a joint for two halves of the crank or does each crankpin have a drag box?Cheers Dan
