...I REALLY need to make that smaller ratchet - getting the screws in on the lower part of the case was tough, not much finger room there. ...
Quote from: crueby on July 22, 2021, 03:04:47 PM...I REALLY need to make that smaller ratchet - getting the screws in on the lower part of the case was tough, not much finger room there. ...I've often wondered why those import 4mm sets didn't include a ratchet for jobs like you're encountering.I wouldn't mind having one but don't feel like making it from scratch as you intend to do. I have a wrench similar to this one... https://www.amazon.com/MulWark-Profile-Ratchet-Quarters-Screwdriver/dp/B07D4DZB1T/ref=sr_1_13?crid=1SY57AG4V54XD&dchild=1&keywords=mini+ratchet+wrench+set&qid=1626972790&sprefix=mini+ratchet+wr%2Caps%2C238&sr=8-13I would take a bit of 1/4" brass hex, drill it out to 4mm, and use the vise to press in a T25 Torx bit to start "hexifying" the hole which would then be filed to shape. A thin sheet metal cover on one end to keep the bits from sliding through and then size this to the thickness of the hex socket in the wrench.If I cut down the shafts on the 4mm bits, I think I could get this arrangement into a 5/8" slot.Just brainstorming right now. I'm waiting to see what you devise and/or the clever Asians introducing one.
Chris:When I saw your ratchet design it never tripped any alarm bells for me. However, when I saw Marv's link it reminded me of what I picked up at Lowes a couple of years ago. https://www.lowes.com/pd/Kobalt-35-Piece-Standard-SAE-and-Metric-Polished-Chrome-Mechanics-Tool-Set/3387640?cm_mmc=shp-_-c-_-prd-_-tol-_-google-_-pla-_-218-_-mechanicstools-_-3387640-_-0&placeholder=null&ds_rl=1286981&gclid=CjwKCAjwruSHBhAtEiwA_qCppjYYZ4et__dH-wQO6l-vncrVx6KPnltpfuDGHhTVbF9lvAw-jo3kUxoC9i4QAvD_BwE&gclsrc=aw.ds (MAN they pack a lot of junk into that link!)At $20 you're not out much if it doesn't work for the Holly. I don't use mine a lot, but when I need to get to a screw in a confined space it's the goto. (It's not worth much on a rusted screw in a bad spot, but then what is?) Don
When you make the ratchet, be sure you chrome plate it and engrave the handle with the "Snap-On" logo. It'll make the elves feel important 'cause you only get the best for them.
Nice work on the flywheels, always amazes me at how you can make such large pieces on such small equipment. Nice feature being able to rotate the headstock
How many times during the ratchet brainstorming session did the shop elves suggest breaking away for another Mann truck run for more Elfensteiner stubbies? (or did they stock up beforehand?)
