Hi ChrisI have a set like this at work and also one at home. It is similar to your proposed design except it uses a spline on each tool to engage the pawl.https://www.newmantools.com/wfmc.htmDave
Quote from: Dave Otto on July 13, 2021, 01:21:08 AMHi ChrisI have a set like this at work and also one at home. It is similar to your proposed design except it uses a spline on each tool to engage the pawl.https://www.newmantools.com/wfmc.htmDaveNice setup- how big is the ratchet head?
Quote from: crueby on July 13, 2021, 02:14:05 AMQuote from: Dave Otto on July 13, 2021, 01:21:08 AMHi ChrisI have a set like this at work and also one at home. It is similar to your proposed design except it uses a spline on each tool to engage the pawl.https://www.newmantools.com/wfmc.htmDaveNice setup- how big is the ratchet head?It is .428" wide and .455" tall, the square part of the head is about 1.2" long.Dave
It does have a pretty stiff spring, so might not work real well is a situation where the fastener does not have much resistance and you can't get a finger on it to add some.Dave
