Yes....looks supurb . ...However I still believe the check valves in the upper plate are of different internal construction to check valves in the lower plate The lower check valves open under vacuum, an admit water to the volunetric capacity equalling the swept volume of the water pistonSo, could the upper plate check valves be bi-directioal? ........[free floating ball]......which would fall under vacuum of the suction stroke, and also allow water to enter the air chamber, but this is limited in water height by the stroke/volume of the water pistonThen, during the pressure stroke the lower check valve closes, and the bi-directional upper check valve also closes so sending the pressurized water on its merry way, leaving the water [level previously explained] trapped in the air chamber? --------------The bi-directioanl check valves would look externally to be identical, but internally have different porting or the omission of a spring in the ball chamber....so is there anything hidden in those original drawings ?Derek
So water passes between the purple and orange parts when open?
Great looking subassembly!
Hi Chris, I had not thought too much about costs with Shapeways. If you need lots of the connectors, yes it could get costly. Is the shape of the connectors spherical or jam-jar 'cylinder with shaped ends' shape? Either way not hard to make a batch from bar stock when all set up. Do you have a toolpost drill spindle accessory for the Sherline, or a Dremel mount bracket? this might speed things up by enabling the (eventually) horizontal holes to be cross-drilled while the bar / connector blank is still chucked. Just food for thought.Now mind you with as many elves as you have in your shop, they may get through the cross drilling pretty quickly!
Sounds good Chris! Are you at making / buying 100 dozen cookies a week yet to keep production levels up?
