This is going to be an epic build! Dave
Quote from: cnr6400 on March 31, 2021, 10:52:35 PMFor casting the original full size hollow frame cores, I would expect that many chaplets would be needed along each core to support them, both under the core and at the sides. The moulders probably used several individual cores to be able to make shorter ones, easier to lift and less prone to breakage. (and they would likely put Shaky the jittery handed moulder on pattern cleaning or counting flasks, the day they were moulding frames.) Chaplets are still available in many shapes and sizes. Link to one local firm carrying them is below. You can often see the residual imprint of one face of the chaplet where it didn't melt right into the casting if you look at big or long castings on old engines. http://smelko.com/?page_id=395 What is a chaplet and how is it used? Never heard that term before. Chiclet, yes, Chaplet, no.
Sounds like a very repeatable process! Which is good, because you'll have to repeat it a LOT of time! Kim
‘ Don
I am maybe a Luddite about the new technologies (or maybe I really just don't have the time ATM) but that to me is impressive
