Quote from: crueby on September 26, 2021, 08:14:10 PM...Hi Chris,What scale are you going to build the engine too,Pluss will you be doing a RC boat for it?Gerald.
And Chris, I suspect those are old pictures...but those cross head guides are about 1/4 th the length that they really are. It's a taper gib plate with a box bearing. The main bearings have wick boxes..., And there has always been a guard on the front of the engine from about 6' below the HP lower cylinder head all the way down to the bed plate. at the bed plate, there is a 6" high copper band, but otherwise the guard is painted red and is held in place with "J" bolts on the front column, and bolts on the port side. It keeps you from getting the coal rake into the cross head, and getting an arm or hand in the cross head. It's coming along nice!.....AS to the other .....suprise......I think a 10,000 HP 4 legged triple from a Great White Fleet battleship. is pretty ambitious!......but its easier if your buddy has the plans for it..... Did you know that this engine is so big, they put staybolts in the HP steam passages?.....Dave
I have also been a long time fan of SABINO. I now live on the river where it was originally operated- it passed by my house several times a day from its launch until it sank in the bridge accident in 1918. I noticed in the CAD animation that the reverse lever was oscillating up and down a bit. If that was constrained would it show the die slip on the link?I just hope you get that engine done and written up soon, I have always want to build one, but was to lazy to do the CAD. I have photos and measurements from back in the day that Dave was operating it.
...... I have photos and measurements from back in the day that Dave was operating it.
I'll be looking forward to the Sabino, Chris.
Looks good Dog, but I bet you didn’t sweat solder them……. Don
Well there was a flat surface there on the top so the solder should of flowed good…..as fir the brass solder would wick very nicely. What I like about sweat soldering is less solder excursion!Don
