Author Topic: Flat twin 60cc  (Read 6397 times)
Offline glorfindel
Flat twin 60cc
« on: March 11, 2021, 02:08:49 PM »
The hirth coupling in the 160cc flat 4 was irritating me, so i decided to do a 'twin'.
60cc, with symetrical cylinders thus the 'fork' configuration of the conrods. Imperial system, 2 rings per piston, 10:1 compression ration (glow)
all allu is 6061t6, crank 1045, push rods, cam shaft and pins are drill rods (w1 tool steel).
here is the 3d model and the crank case i made so far.
« Last Edit: March 13, 2021, 12:20:34 PM by glorfindel »
Re: Flat twin 60cc
« Reply #1 on: March 11, 2021, 03:17:41 PM »
Off to a good start.
That looks a bit more than the usual hobby benchtop CNC  :o have you posted about it elsewhere and I've missed it
Re: Flat twin 60cc
« Reply #2 on: March 11, 2021, 08:20:07 PM »
He is a CNC teacher and does this for a job  :)  :)  :) It's a 5 axis DMG 1250CTX mill/turn
https://www.modelenginemaker.com/index.php/topic,8770.msg195434.html#msg195434
Re: Flat twin 60cc
« Reply #3 on: March 11, 2021, 08:29:56 PM »
Thanks Roger, bit of reading for me there (well looking at pictures)
Offline glorfindel
Re: Flat twin 60cc
« Reply #4 on: March 11, 2021, 09:06:06 PM »
Im teaching machanical engineering since 1997 ;-)
I'm a CatiaV5 cad/cam/fea teacher that appears to like engines and motor sports. ;-)
The final project i gave this week to one of my class is to design a small 15-30cc single 4 strokes engines.
Kids like that ;-)
So far, i made the edward radial 5, wich is 99% done, only intakes missing.
I also made a derived engine from the Nemett 15, wich is working.
Now i work on the 60cc twin. ;-)
Sorry for my bad english, french is my first language.
Btw, the cnc on the pic is a DMG DMU 50, 5 axis mill.
The DMG CTX 1250 was crashed by a student and is waiting for a new head ;-)
Envoyé de mon SM-N975W en utilisant Tapatalk
Offline glorfindel
Re: Flat twin 60cc
« Reply #5 on: March 16, 2021, 06:10:18 PM »
Since the tcx1250 is off duty, i did the sleeves the old way ;-)
C12L14 Reamed to 1-3/8"
Re: Flat twin 60cc
« Reply #6 on: March 16, 2021, 08:13:27 PM »
Looking good  :ThumbsUp: Your English is fine  :) I am well aware what my German sounds like to the locals ( I am English and living in German Switzerland).
Offline glorfindel
Re: Flat twin 60cc
« Reply #7 on: March 17, 2021, 05:49:23 PM »
Did the first step of the Rocker Support!!
Offline glorfindel
Re: Flat twin 60cc
« Reply #8 on: March 19, 2021, 08:17:00 PM »
Did some work today.
Offline glorfindel
Re: Flat twin 60cc
« Reply #9 on: March 26, 2021, 01:35:59 PM »
New parts done!! Glow plug hole missing.
Offline glorfindel
Re: Flat twin 60cc
« Reply #10 on: April 07, 2021, 02:46:26 AM »
I didnt like the bolt pattern and the threads for the intake/exhaust ports. So i redesigned it with a new bolt pattern and flanged intake/exhaust.
No need to do left/right side anymore.
Offline glorfindel
Re: Flat twin 60cc
« Reply #11 on: April 07, 2021, 08:04:01 PM »
Did the nose and the rockers today.
Offline AVTUR
  • West of England
Re: Flat twin 60cc
« Reply #12 on: April 08, 2021, 01:01:22 PM »
A nice engine - neither too simple nor too complex.
Is this your own design or are you making it from someone else's drawings?
AVTUR
Offline glorfindel
Re: Flat twin 60cc
« Reply #13 on: April 08, 2021, 02:51:00 PM »
AVTUR
I ordered the Jung flat 4 160cc plans and turned it in a 60cc flat twin , with new rods (fork configuration),  heads, pistons, rings, imperial measures (1-3/8" bore) etc...
I got lots of plans, taking idea left and right.
Offline glorfindel
Re: Flat twin 60cc
« Reply #14 on: April 08, 2021, 10:29:52 PM »
Cages done!! I used bronzebushing material.
