Elmer's directions say use "graphited asbestos packing." I think I'll use something else.
As Chris says, many ways to do the angle on the base. For those with a few dollars left in the tool budget (no idea who has that), and who are lazy in setups (like me) you can buy endmills with a taper angle ground on. The example at the link below is 5 degrees. Suppliers have many angles, but usually in increments of a full degree. With these tapered mills, you make a normal endmill cut and the surface is cut at the taper angle. Very handy for mould and pattern making. Hope this info helps. https://www.mcmaster.com/8936A37/
Might be a good time to add a Tilting Angle Table to your tooling:
