Author Topic: ED hunter mark 4 carburetor  (Read 386 times)
Offline Dan the man
  • Jr. member
« on: February 21, 2021, 10:15:22 AM »
Hi folks ,I own a ed hunter for decades and only recently got it running with a modified os carburetor, but its difficult to start.
I'm wondering if someone has a carb for sale or drawings of one?
Dan the man
Offline Ramon
  • Suffolk in the UK
Re: ED hunter mark 4 carburetor
« Reply #1 on: February 21, 2021, 12:12:04 PM »
Hi Dan, The Ed 3.46 Hunter is a particular favourite  :ThumbsUp:
I haven't got a spare carb nor a drawing as such but some time back I made a 5cc version - heres a pic of the carb parts which were copied directly off an original Hunter.
These were made to a scale of 1.13 the original.
I have a PDF file of the backplate showing the carb at that scale but not sure how to attach it - Pm your email and I'll send you it
Tug
Offline Ramon
  • Suffolk in the UK
« Reply #2 on: February 21, 2021, 11:02:44 PM »
Hello Dan - Received your PM
I just tried to send you an email but it has returned. It appears to be due to a change over of servers this last week. I thought I had sorted it but apparently not so. I don't really have much idea about such things so that might be a while
Can any one help me get a PDF up on here for Dan ?
Regards - Tug
« Reply #3 on: February 22, 2021, 05:50:05 AM »
Hi Ramon
How's life?
Regarding the pdf file I can see that it is attached to your post with the photo of the carb.
Offline Ramon
  • Suffolk in the UK
« Reply #4 on: February 22, 2021, 08:01:17 AM »
Hello Vince, It's still good but slowing down a bit now  ::) Hope you are enjoying that retirement  :ThumbsUp:
I can see the attachment now, thanks. When I added the attachment, once in the box there was nothing to say insert or such so I assumed it hadn't worked.
There you go then Dan - the attachment of the drawing is at the bottom of my reply. That should get you what you want - just divide the dimensions by 1.13 and that will be the original specs. Unfortuntely I don't appear to have a drawing of the needle valve assembly (may be on another computer that isn't set up at the moment) so can't help there for now
(Ramon) Tug
Offline Dan the man
  • Jr. member
« Reply #5 on: February 22, 2021, 11:12:57 AM »
Thanks for that Ramon,brilliant!I actually have the needle assembly ordered so I will now have a go at making the carb body
Dan
Offline Ramon
  • Suffolk in the UK
« Reply #6 on: February 22, 2021, 02:18:09 PM »
You're welcome Dan.
Let us know how you get on and watch those fingers - an ED 3.46 has a good reputation for biting!
I don't know what it is about the Hunter but I have always found it to be a very attractive engine - Since building my 5cc version I now have three of the original size!
You may be interested in taking a look here https://www.modelenginemaker.com/index.php/topic,7914.15.html
Good luck with yours - Tug
