Hello Vince, It's still good but slowing down a bit now
Hope you are enjoying that retirement
I can see the attachment now, thanks. When I added the attachment, once in the box there was nothing to say insert or such so I assumed it hadn't worked.
There you go then Dan - the attachment of the drawing is at the bottom of my reply. That should get you what you want - just divide the dimensions by 1.13 and that will be the original specs. Unfortuntely I don't appear to have a drawing of the needle valve assembly (may be on another computer that isn't set up at the moment) so can't help there for now
(Ramon) Tug
