Author Topic: Valve seat cutting  (Read 3460 times)
Offline Amblejo1
Re: Valve seat cutting
« Reply #15 on: February 18, 2021, 10:55:16 AM »
Many thanks for posting the drawing of the seat cutting tool George.
That will help me a great deal.
It will probably take me much longer to make the tool than it will to cut the valve seats, but there is great satisfaction to gained from doing a job well isn't there?
« Reply #16 on: February 18, 2021, 11:54:21 PM »
I just have to reply to this. I haven't made George's valve seating tool but I do plan to, using Dave's 5 tooth design. Brian I have to say this forum would be much different today had you taken up tap dancing. :lolb: I do have a friend who can heat treat stuff for me but it has to be S7 to not send up red flags.
Offline tangler
  • Christchurch, UK
« Reply #17 on: February 19, 2021, 02:23:05 PM »
Here's mine, a simple guided D bit (with an odd number of cutters - 1  :) )
Stay well,
Rod
Offline pgp001
  • West Yorkshire - UK
« Reply #18 on: February 19, 2021, 03:03:54 PM »
Here is a tool I made for re-cutting the valve seats on my Austin Seven engine, it based on an R8 collet blank.
The actual cutter is made from a broken 1/4" screwed shank end mill.
I also opened out the throats with a boring head to get better gas flow.
Phil
« Last Edit: February 19, 2021, 03:09:19 PM by pgp001 »
