The aluminum end pads had a little bleed hole drilled through which I learned the hard way is required, otherwise they can ‘hydraulic’ when the Loctite is applied & can set up in an incorrect position. I left the diameters slightly oversize so that once bonded, they get blended to the pin diameter, chamfered & finish length in one lathe operation.
