Is it just me?I don't see any of the pictures.I'm logged in.Hmmmmmmm???Sid
You get a lot less torque load on the clutches if they work @ full engine RPM - but this means that you need four two speed boxes -> no go .... wonder if it's possible to scale the modern slipper clutches down They use a ramp system -> when the torque is coming from the wheel it looses the spring pressure on the plates and when it's from the engine the ramp works the other way and grips even harder on the plates ....Still following along
