Hi - I am making it x 1.5 bigger and have redrawn all the parts. All of the bigger parts are completed, just valve gear etc to make now. I have struggled with a few of the drawings but the one with the least detail seems to be the whole base - no problem as I will complete the engine and then machine the base to fit. It is a very simple build and most enjoyable - although there are a lot of holes to drill and tap! I have used the imperial drawings as they are more suited to how I read drawings (simple!)
Three of us have/are making the original Arnold Throp Corliss engine using the original drawings.I do not know of anyone who is using Julius' drawings. I have not checked them myselfJo
Jo - you have obviously dismissed my description of the origins of this engine on my thread on here and in the past.Yes the engine was designed by Arnold Throp but it was on the commission of Terry Fleet of Fleet Engineering Services. It was sold by and not through Fleet Services and it was Terry that made all the patterns for the various versions that the engine can be built in. These were placed at a foundry that overnight shut down and 'disappeared' that not only meant the loss of the patterns but a considerable amount of paid for outstanding casting work. It was the loss of these patterns that caused the loss of this design to the ME world for several years. That is not perceived info but directly from Terry Fleet himself who assures me he still technically holds all rights to the design though has no longer any desire to be concerened with itArnold made patterns for just a single cylinder condensing version that was described in Model Engineer in the 1980's just when Fleet first advertised it. From the conversations I had with Peter Southworth it was never sold by Arnold and was not 'passed' to him.As I have already described to you before, a conversation with Peter lead to him (Peter) telling me he had bought the patterns and drawings for that single cylinder at, quote' "A sale of Arnold's estate". It was that conversation that lead to the making of patterns for the rest of the design to which I built my engine. For some reason you seem to have a reluctance to accept this but I still have the letter from Peter telling me that which as you should recall I have posted before.I have no personal interest in the matter as such but if you make a clear statement, you should be sure of the facts and relay them relatively.
Well that's a bit of a jump from an S50 to the Corliss particularly if you stick with Julius sizes that produce a larger engine. Had a quick look over the drawings and as usual there are some features that could not be machined as shown but a bit of an alteration to the design, or fabrication in place of cutting from solid should sort that out not to mention copious use of JBWeld.I know that Blackgates took over the patterns for the "Lincoln" range that Southworth did as well as the pumps so they may well also have the Corliss ones. I know one of the members here was trying to get a set of the Lincoln ones from them but gave up after a very long wait so don't know if or when they may be able to supply anything for the Corliss.
Fizzy bought it !
