Author Topic: Holt 75 from Germany  (Read 14668 times)
Offline michelko
Re: Holt 75 from Germany
« Reply #45 on: October 01, 2022, 05:55:21 PM »
Your gear train looks great, Michael!   :ThumbsUp: :popcorn:
I assume the clamps on the mill are to keep the spindle from turning during the broaching operation?  Interesting use of a mill!
Yes i was a liitle lazy and did it the Quick and dirty way. Some day i will build a clamp for the spindle, ...maybe ;D
« Reply #46 on: October 01, 2022, 07:59:00 PM »
Always great to see and feel it all go round and round, up and down as it should  :praise2:   :cheers:
I haven't seen broaching done on a Mill before - but as some here are doing the similar thing with Drill-Presses and Lathes - why not the Mill  ;D  and the result speaks for itself  :ThumbsUp:
Offline michelko
« Reply #47 on: October 04, 2022, 10:38:18 AM »
Hi
did the rockers yesterday. The body is milled from an round stock of steel. The round part with the thread is silversoldered to the main part.
I decided to go this way instead of the adjustable pushrod.
The bore will get a brass/bronce bushing.
Still have to clean them.
Regards Michael
« Reply #48 on: October 15, 2022, 08:00:35 AM »
That's a nice set of rockers  :praise2:  I like the use of the CNC mill for broaching the keyway  :ThumbsUp:  :ThumbsUp: I haven't seen that before.
« Reply #49 on: October 15, 2022, 12:02:41 PM »
Still following along.  Nice work on the rockers!
Offline michelko
« Reply #50 on: January 31, 2023, 08:16:12 AM »
Hi
just found some time to make the gearhousing.
Came out nice.
Next will be the cover.
Greets Michael
« Reply #51 on: January 31, 2023, 10:50:21 AM »
Good to see progress and I can see why you are very happy with the latests parts  :ThumbsUp:
Per          :cheers:
« Reply #52 on: January 31, 2023, 03:16:51 PM »
That gear housing does look very nice indeed! :ThumbsUp:
The Bugatti engine hiding under the towel must be the same one as in your avatar? Did you do a thread on that one also? (edit) Found it.
« Last Edit: January 31, 2023, 04:00:42 PM by RReid »
Offline michelko
« Reply #53 on: February 06, 2023, 11:30:12 AM »
Hi guys and thanks for your replies.
Yesterday i made the gearbox cover.
I changed the designe a little bit so i could use lipp-rings as shaft sealing to avoid excessive oil loss.
Used tape and superglue to hold the workpiece on the table.
Worked realy nice.
Just had to sand the mill marks away.
Regards Michael
Online Vixen
« Reply #54 on: February 06, 2023, 12:34:02 PM »
Worked realy nice.
Regards Michael
Another fine piece of metal sculpture. Nice work. :ThumbsUp: :ThumbsUp: :ThumbsUp:
I am surprised tape and superglue was enough to hold the workpiece. It must depend on having a large glued area.
Offline michelko
« Reply #55 on: February 06, 2023, 12:38:53 PM »
Yes its amazing. Used this method also for the side plates on the Bugatti Build with great success.
Regards Michael
« Reply #56 on: February 06, 2023, 05:27:34 PM »
I've had excellent success using double sticky tape to hold two pieces together that need to be milled/drilled identically, and it holds pieces surprisingly well. But as you say, it is based on the area covered by the tape.  If it's a very small piece with little surface area, it doesn't work as well.
Michael, when you say tape and superglue, are you using single-sided tape, so the adhesive of the tape holds one side, and superglue holds the tape to the other side?  Or something else?
Thanks,
Offline michelko
« Reply #57 on: February 06, 2023, 06:59:24 PM »
Hi kim i used a kind of masking tape.
« Reply #58 on: February 06, 2023, 10:58:11 PM »
Single-sided masking tape? Or double-sided?
And where/how did you use the superglue?
« Reply #59 on: February 07, 2023, 01:15:57 AM »
Hi Kim
Have a look here.
<a href="https://www.youtube.com/watch?v=e-coDYZCmEw" target="_blank">http://www.youtube.com/watch?v=e-coDYZCmEw</a>
