Author Topic: Bar-stock "Mary"  (Read 13245 times)
Offline cwelkie
Re: Bar-stock "Mary"
« Reply #60 on: March 05, 2021, 10:44:14 PM »
Lovely work and wonderful lessons in how it can be done without castings to good effect.
Thanks for sharing this build.
Charlie
Offline joe d
  • Montreal, Canada
« Reply #61 on: March 06, 2021, 12:34:02 AM »
Tug, Bear, Charlie:
Thanks guys!
Joe
« Reply #62 on: March 06, 2021, 01:27:05 AM »
Just finish reading from start to finish Joe. Don’t know how I missed it but that is some great fabrication work. I will be following till the end.... :Love:
 :drinking-41:
Offline joe d
  • Montreal, Canada
« Reply #63 on: March 06, 2021, 04:03:49 PM »
Thanks, Don.  Glad to have you looking in!
Offline joe d
  • Montreal, Canada
« Reply #64 on: March 13, 2021, 03:54:32 AM »
A short detour into some wood-working for the base.  Had some oak off-cuts from a little project I had done for one of the daughters-in-law
so put them to use.
Viewed from the underside:
But it does have some metal work: made up a a well for the flywheel from some brass sheet, little bits of tube as spacers, & soft soldered it all
together
The base from above
and with the flywheel well in place:
Also made up a well for the crank, it fastens to the underside of the aluminum base.  There is enough clearance between the metal base plate and the wooden base, so this is not essential,
I may well omit it eventually, if so, will just cover the hole in the wooden base with some flat stuff.  This has also been my test piece for paint, it's been green, red, and now brown, not crazy about any of them so far...
a bunch of studs to attach everything to the base
A quick turning job to make the trunnion for the beam (here it's chucked up for polishing)
in place
and with the bits fastened to the wood base, and the beam perched in it's spot:
Cheers, Joe
Offline Bear
  • Idaho, USA
« Reply #65 on: March 13, 2021, 04:07:06 AM »
Impressive work, Joe.
Offline joe d
  • Montreal, Canada
« Reply #66 on: March 13, 2021, 04:58:30 PM »
 Thanks Bear!
Joe
« Reply #67 on: March 13, 2021, 06:54:58 PM »
Look really good now that one truly can see what it should end up as  :cheers:
Still following  :popcorn:
Offline joe d
  • Montreal, Canada
« Reply #68 on: March 14, 2021, 01:45:14 PM »
Thanks Per.  I agree, a mile-stone moment once it's all sitting on it's base, it's encouraging!
Joe
Offline joe d
  • Montreal, Canada
« Reply #69 on: March 19, 2021, 03:16:49 AM »
Flywheel part one... a lot o photos of this, so I'm breaking it up into 3 posts.
Pretty much made this up as I went along based on what material I had on hand.
Cut 6 pieces of the mystery brass, drilled hold-down holes in what would eventually be waste,
screwed down on a sacrificial bit of aluminum on the rotary table and cut the sides to the requisite angle
In the same set up, ran a light cut to define the inside radius, and then chain drilled the lot
Hacksawed off the waste and then back to the mill to clean up the arc
Then chain drilled the outer arc, and as above, sawed off the excess and cleaned it up on the mill
This took away the hold-down holes, so had to clamp the work to the table, but happily, nothing moved throughout the process
Then drilled the centre of each segment radially, with a short counterbore on the inner side, for fitting the spokes
More to come....
Offline joe d
  • Montreal, Canada
« Reply #70 on: March 19, 2021, 03:33:11 AM »
fly wheel part 2...
Chucked a length of brass, drilled and counterbored the size of the spoke material
Added a little decorative cut, and then parted off, repeat 5 more times
cut 6 pieces of stock for the spokes, turned down one end and threaded them on the lathe
Turned them about and turned a short length to the diameter of the counter bore in the rim segment, with a further length smaller
to the diameter of the through hole in the rim segment
Stuck together just to see how it was coming...
Cleaned up a bit of brass in my larger lathe to create a chucking piece for the small lathe
Once trued up on the Taig lathe, cleaned it up ready to move to the mill
The point to doing the set up on the Taig lathe is that the Taig chuck fits the indexing head built for the Taig mill
So, here drilled 6 equidistant holes, counterbored them to fit the decorative bits made earlier, and tapped to fit the threads
on the spokes.  (This threading is simply to hold things together for soldering)
more to come...
Offline joe d
  • Montreal, Canada
« Reply #71 on: March 19, 2021, 03:45:32 AM »
Flywheel part 3
Test fit:
Looked good, so went ahead and tapered the spokes
5 down, 1 to go...
Cleaned up all mating faces, fluxed and clamped down & silver soldered
set up as true as I could on a faceplate, ready to clean up the rim, hub, and drill & bore the hub
Flipped around, centred by putting a little stub in the shaft hole, cleaned up the reverse side and removed the excess
on the hub
( and could not find a speed or feed that this crap brass liked to get a clean cut radially,  glad I've almost run out of it!)
Broached the keyway in the arbor press, and here it is sitting where it belongs:
Big job done!  Cheers. Joe
Offline Bear
  • Idaho, USA
« Reply #72 on: March 19, 2021, 03:52:23 AM »
Looking awesome!
Offline joe d
  • Montreal, Canada
« Reply #73 on: March 19, 2021, 03:56:49 AM »
Thanks, Bear!
« Reply #74 on: March 19, 2021, 04:11:25 AM »
Wow!  That was a lot of work, but the results look great!
