I love the fact that you're building this with a Sherline. (I've got both a Sherline and a Unimat.)The fact that you're mostly building it out of steel is even more impressive. Why did you chose to use steel for the block and heads over something easier to machine like aluminum or brass?Don
Really nice work, Steve!I don't have a lot of experience with IC engines. So can you help me understand the difference between the Left, Right and Universal heads? All three look the same to me.Thanks,Kim
Quote from: Kim on November 28, 2020, 05:18:17 PMI don't have a lot of experience with IC engines. So can you help me understand the difference between the Left, Right and Universal heads? All three look the same to me.There is no real difference between left and right - the holes are effectively symmetrical. I've just given an extra mil of metal at the front end of each to accommodate cam gears. The universal has an extra mil at both ends.
