Author Topic: Cosworth V8 1:12 scale  (Read 10927 times)
Re: Cosworth V8 1:12 scale
« Reply #60 on: December 04, 2021, 02:57:05 AM »
Steve,
It looks like you've been up to some very intricate work, twice. Looks very good.
« Reply #61 on: December 04, 2021, 10:24:33 PM »
That's coming along beautifully Steve!!!
Offline Steve Crow
« Reply #62 on: December 06, 2021, 03:13:13 PM »
One of the most fiddly things on this build was hand fettling the bearing blocks so the camshaft turns freely with a minimum of play.
The cam shafts are supported by a sort of shell bearing. These were made by turning down brass bar to 2mm and boring out to 1.6mm.
These were then trimmed down to a semi circular C-section and burnished/work-hardened into place using a polished steel 1.6mm rod.
They are now held firmly in place by there own springiness.
I'm making all this up as I go along but it seems to be working fine.
« Reply #63 on: December 06, 2021, 05:02:19 PM »
Quite impressive!!
Offline Steve Crow
« Reply #64 on: December 07, 2021, 11:02:01 PM »
My next challenge is to finish the cam gear train. The principal gears are in place and running smoothly, I just need to sort out the idler gears.
Here are some sat in their final position.
« Reply #65 on: December 08, 2021, 11:22:49 AM »
Very nice progress  :ThumbsUp:
You are not doing things the easy way ...!
Since you have very small tollerances on the placement of these gears - are you placing the axels on excentrics so you can adjust them ?
Offline Steve Crow
« Reply #66 on: May 28, 2022, 05:23:10 PM »
It's time I resurrected this thread. I've had a couple of months off metalwork but I'm back into it now.
Yesterday, two years to the day from the first idea and drawing, I finally finished making all the major components.
I've completed the task I dreaded most. The valves, guides, tappets and springs - 32 of each.
The valves took the most time as they are rather small with quite tight tolerances. Each one needs 8 machining processes.
Here's 16 of them on a penny.
And a close up of one so you can see the slot.
At this magnification, you can see bits of paste from when I ground them into their seats.
Offline Steve Crow
« Reply #67 on: May 28, 2022, 06:37:43 PM »
Here's how the valve parts fit together, open and closed.
The valve guides are brass and reamed with a 1.026mm carbide reamer (Jurassic Tools - great price). They are a friction fit in the cylinder head and the springs keep them seated.
The tappets are adjustable using the 3 holes and the slot in the valve using a tool that I have not finished yet.
Here is a tappet and an untrimmed spring. And a penny.
Offline A7er
  • Cornwall, UK
« Reply #68 on: May 28, 2022, 08:16:23 PM »
A great piece of work! I haven't read through the whole process to see if you have already covered this question, but why 1/12th scale?
Offline Steve Crow
« Reply #69 on: May 29, 2022, 10:37:59 AM »
It's the smallest I could get away with! Also, it's easy to scale from the imperial measurements of the original. The block fits nicely into a 1 inch square bar, look at my earliest pictures.
Offline Steve Crow
« Reply #70 on: May 29, 2022, 10:44:41 AM »
Here is one cylinder head with valve gear installed and a cam carrier behind it.
Valves, tappets and springs (and spares) for the other head.
« Reply #71 on: May 29, 2022, 10:14:34 PM »
Very impressive work and scale  :praise2:
I can't remember, but you are getting close to first run, aren't you ?
