Quote from: Alyn Foundry on December 04, 2020, 03:53:07 PMOh my goodness Jo, just over 2 Kg.... That is just over 200 grams The rod weighs 50 grams.. so the displacer is only 3/4 of the weight.Jo
I'm going to fit a cooling tank and then see if it will run before I modify anythingJo
The solution would be either to use an " O " ring at the bottom end or perhaps easier to use a more flexible sealant like Silicon Rubber.
I wonder if the liner could be aluminium Jo
If you went with a hub mounted 3 step pully like the originals had then if made from iron or steel you could hollow out an eccentric hole at the back of the pulley which would help with balance. With a bit of cunning the modified hub could be made from a mix of aluminium on one side and steel on the other to add more hidden counter balance.
