Author Topic: Write out 100 times "I must use my brain more often"  (Read 2071 times)
Offline Rik Shaw
« on: November 17, 2012, 12:01:29 PM »
Thanks to Jon Bogstand for your input on another thread re: my new twice full size "duck" I will try not to make the same mistake as I did with my first largish (8kilos) stationary steamer.
I doubled the dimensions on that one as well only to find that the completed crankshaft was badly out of balance. I had not taken into account that doubling the dimensions of the crankshaft webs was completely the wrong thing to do. The right way should have been to double the weight ? NOT the dimensions. i.e.: A one inch cube of mild steel weighs .2833 lbs. Double the size to a two inch cube and you get not 2 x .2833=.5666 but 8 x .2833=2.2664.
I put on my dunces hat and stood in the corner while trying to remember the formula for calculating the volume of a cone ? what a dimbo!!  :facepalm:
Offline ScroungerLee
Re: Write out 100 times "I must use my brain more often"
« Reply #1 on: November 17, 2012, 12:40:59 PM »
Good point, I probably would have made the same error.  Thanks for the learnin'. :)
Lee
Mmmmm.... Shiny!
