Author Topic: repair of an old stationary steam model  (Read 8623 times)
Offline Johnmcc69
  • Erie Pa., USA
Re: repair of an old stationary steam model
« Reply #15 on: August 04, 2019, 02:01:46 AM »
Very nice!
Offline rarach22
« Reply #16 on: August 05, 2019, 09:25:32 PM »
Offline rarach22
« Reply #17 on: September 07, 2019, 09:09:12 PM »
Offline MJM460
« Reply #18 on: September 08, 2019, 11:03:35 AM »
Good to see the beautiful work progressing.
Is that a SS boiler in progress as well?
Offline rarach22
« Reply #19 on: September 08, 2019, 07:50:06 PM »
s
yes boiler will be stainless steel .... type cochran boiler
Offline rarach22
« Reply #20 on: September 08, 2019, 08:09:16 PM »
Offline rarach22
« Reply #21 on: September 09, 2019, 10:14:13 PM »
Offline Johnmcc69
  • Erie Pa., USA
« Reply #22 on: September 10, 2019, 02:20:41 AM »
That's some really nice work Pavel!
 You are a craftsmen!
« Reply #23 on: September 10, 2019, 06:38:35 AM »
Interesting angle of engagement for the grub screw Pavel........
1. is the main shaft a replacement?
2. will you make a flat or dimple the shaft to allow the grub screw to engage at such an angle?
3. the cylinder appears to be 50 mm........or is it 2"?
4. not usual to see Continental/European grub screws with a screwdriver flat......so is the original English?
Derek
« Last Edit: September 10, 2019, 06:42:35 AM by derekwarner »
Offline rarach22
« Reply #24 on: September 10, 2019, 07:38:03 AM »
Derek
Hi Derek,
the screw will touch on the shaft, where there will be a small area, the original steam engine is only a bronze cast of the cylinder, everything else I do from my drawings
Offline rarach22
« Reply #25 on: September 16, 2019, 10:48:13 PM »
Offline MJM460
« Reply #26 on: September 16, 2019, 10:52:27 PM »
Well done, a most interesting design.
Offline rarach22
« Reply #27 on: September 26, 2019, 08:39:11 PM »
Offline rarach22
« Reply #28 on: September 27, 2019, 07:40:00 PM »
« Reply #29 on: September 28, 2019, 08:29:25 AM »
Pavel.......a question......
The valve on the right side appears as a rotating spindle [globe valve or needle valve with the bonnet bolted to the body] & typical of an Isolation Valve which you have shown on previous builds.......
The valve on the left appears as a rising spindle valve with the bonnet screwed into the body, [and actuated via an external mechanism bolted within or to the connected hoop ?] so if this is the case is an early version of a speed Control Valve?
We also see you have changed from a 4 bolt pattern to a 5 bolt pattern.........any reason for this?  :shrug:
Derek  :cheers:
« Last Edit: September 28, 2019, 08:36:18 AM by derekwarner »
