Author Topic: OHC 4 stroke datsun engine timing questions  (Read 2558 times)
Offline Longboy
Re: OHC 4 stroke datsun engine timing questions
« Reply #15 on: February 14, 2019, 06:43:39 AM »
[/quote]
I'm making an L16, used in a bunch of different Datsuns from pretty much 68-79............... This is my first engine project ever so any pointes would be cool.
and for the lower pulley this is how I image it could work. There's .165 for the threads to hold onto.
[/quote]
I see it now with the large hub behind the flange. On the water pump box.......maybe you could extend that rectangle shape out to the right some ( in photo) or just enlarge it for more internal room setting up the belt pulleys and still be true to the original engine external looks.
Most of the modelers here with years behind them are going say start out with a simpler, newbie project engine. CNC can make the transition from simple to complex quicker. Hands on, human experience....not so fast. Continue your work if comfortable, your Datsun engine can be set aside if needed for another day as you get more time behind you.
Offline Bluechip
  • Derbyshire
« Reply #16 on: February 14, 2019, 08:35:41 AM »
Quote should be from theeoracle ...
One of those powered my 1972 510 Estate ( wagon ? )
After the vagaries of the rubbishy Ford Cortina 1600E that preceded it the reliability of the Datsun was a revelation.
Fond memories ... Except it came with white-wall cross-ply tyres .... Soon dumped them before they dumped me ...  :)
Don't help you to model the engine though.  :thinking:
« Last Edit: February 14, 2019, 08:38:58 AM by Bluechip »
Offline theeoracle
« Reply #17 on: February 15, 2019, 04:23:26 PM »
[/quote]
[/quote]
I do have a question regarding the oiling system though. Do you think I need through crank oiling like in a real car or do you think having the crank splash in oil is enough? The crank will have bronze oil bearings. Also for the camshaft oiling I plan on using a spray bar and a low pressure pump that I will make. Do you think that would work with 8 outlets for each cam?
« Reply #18 on: February 15, 2019, 08:39:37 PM »
Lubrication is always a good question and not always an easy one to answer as there are several factors involved.
The size of the workload is one of the biggest factors, so let's start here. :
How big is the engine - bore, stroke and compression (the last can usually be answered with the CAD program you're using) ?
How big will the load be ? - RPM ?
What kind of fuel will you be using ?
Cylinders / pistons can usually get plenty of oil from the fuel with 1-2% oil in it and splash lubrication is in most cases plenty in this area. Con rods again, can often get away with plash lubrication and all ball bearing are very happy with an oil mist (actually preferred). Camshafts and crankshaft bearings vary, as plain bearing often require pressure to work, but that is again VERY load dependent. The cams themselves are happy with splash lube.
OS model latest FS series four-stroke aero engines are only lubricated from a bit of oil in the fuel and a genially  simple system of channels that uses the unavoidable higher pressure in the crankcase + the fact that some of the oil in the fuel ends up there, to move that oil through the crank bearings to the camshaft. From there it goes through the pushrod tubes to the cylinder head where it lubes the valves etc. and goes back to the inlet through a very small hole, get sucked back in and the hole thing repeats  :praise2:
Offline theeoracle
« Reply #19 on: February 16, 2019, 05:10:24 AM »
So for now there is no intended use other than to run it on a stand.
The bore is .96 and stroke is .96. The conrods will have bronze oil bearings on them, same with the mains. As for the camshaft it will look the same as in the picture. Some Datsun L series engines used a spray bar for the camshaft. I will try that on my valvetrain. I guess my question is if I use a spray bar and drill 8 holes for each lobe and the oil comes from the center of the tube will I get even flow throughout the whole tube? or do I need to drill progressively larger holes further out.
« Reply #20 on: February 16, 2019, 07:36:57 AM »
For short runs off load on a stand on a stand splash lubrication should be fine for the bottom end. You will need something for the OHC. This could be as simple as remove the rocker cover and give the cams and drive gears a squirt from an oil can before you start.
« Reply #21 on: February 16, 2019, 11:50:46 AM »
That amount of CC's is enough to warrant pressure oiling of the mains if it is loaded for sure or sustained runs …. but Roger might be right about just a plash in all the right places before a run - I hope some of the builders of bigger 4, 6 & 8 cylinder engines here will chime in, though I'm sure that they all have presure oiling. This should be possible in an engine of this size and to an extent required for a scale model.
The next part of your question - yes all oil lines / galleries have a certain internal diameter and a much smaller outlet at each oiling point in order to keep the presure in the system + make sure all places get what they need. On full size engines you will often find jets like the ones in an old carb in the oil lines (except that you can't change them). The jets over the cams create a spray pattern as it both cools and lubes better than a constant flow of oil there - in performance engines.
Offline theeoracle
« Reply #22 on: February 16, 2019, 04:49:35 PM »
If I really need pressured oil going to the mains, would I also need the rods to be pressured? How would I go about doing this. I know conley uses his hole popper EDM. I could probably find someone who has one.
« Reply #23 on: February 17, 2019, 10:41:43 PM »
You "only" need to drill a small hole from the main bearing to the throw in the crank in order to lube the big-end of the con-rod as the small end never is pressure lubricated.
There are several engines here on site where you can see it done with pictures and accompanying text.
George Britnell comes to mind as one of the masters here, but he is absolutely not the only one - have a look under Engines - your own design.
Offline theeoracle
« Reply #24 on: February 18, 2019, 02:45:31 AM »
cool thanks
I finished the water pump today.
I am super happy with the way it turned out.
<a href="http://www.youtube.com/watch?v=HGlv9gJG6h0" target="_blank">http://www.youtube.com/watch?v=HGlv9gJG6h0</a>
<a href="http://www.youtube.com/watch?v=F18DgD9Nd5Q" target="_blank">http://www.youtube.com/watch?v=F18DgD9Nd5Q</a>
Offline Jack3m
  • Washougal WA
« Reply #25 on: March 20, 2019, 07:54:25 PM »
I used to work on the L16 professionally in the day.  The tensioning was done by oil pressure pushing out a shoe type device that ran against the chain.  Frankly it has been so long I really don't remember exactly how we timed it, but it was adjustable, one of 3 choices on the cam gear.  Had some dots that had to line up on chain and pulley as I remember also.  If you did not know what you were doing it really was a mess.
I see with the water pump pully you are not going full scale, so maybe it doesn't matter to you.  Still a cool project.
Jack of all trades, master of none
