Author Topic: Edwards 5 Cylinders.  (Read 27757 times)
Re: Edwards 5 Cylinders.
« Reply #105 on: May 09, 2019, 04:46:09 PM »
Oh man - that could have happened to me too  :facepalm2: - maybe paint the 1/4" red on the shaft as a warning in the future  :thinking:
Since there is a lot of work in the masterrod - do you open the rest (or at least one piston for a 1/4" pin, change the bronze bearing (if there is one) is probably the easiest ….
Offline glorfindel
« Reply #106 on: May 09, 2019, 06:41:19 PM »
I made 2 of those some times ago.
When you got all the cnc prog done, it's easy to do a couple of those ;-)
Envoyé de mon SM-G965W en utilisant Tapatalk
Offline petertha
« Reply #107 on: May 09, 2019, 08:04:17 PM »
The ends are a little bit bigger than the pin, so i hope it will do the job.
Not quite sure what you mean there. I assume pads have to be the same diameter as wristpin to recess in the pistons hole? And the wristpin length + 2 pads must be less than bore by some clearance amount? What am I missing?
Offline glorfindel
« Reply #108 on: May 09, 2019, 08:09:08 PM »
The pads are a little bit bigger (diameter) than the wristpin, so they should stay in place.
« Reply #109 on: May 09, 2019, 10:10:54 PM »
Yes, but that way, they might also be a pain in the proverbial if you ever need to get things apart again ....
Offline glorfindel
« Reply #110 on: May 09, 2019, 11:32:00 PM »
I hope a gentle tap will do the job ;-)
Offline glorfindel
« Reply #111 on: May 10, 2019, 06:14:04 PM »
Ring blank is ready to be sliced by the wire edm.
Then the will be heat threated at 950F for about 10min.
Offline glorfindel
« Reply #112 on: May 13, 2019, 04:15:30 PM »
Waiting to be sliced.
Offline glorfindel
« Reply #113 on: May 14, 2019, 07:31:46 PM »
Heat treatment seems to have worked!!!
No big deal with TTT curves.
Offline glorfindel
« Reply #114 on: May 14, 2019, 10:07:39 PM »
For those who are not familiar with ttt curves.
Offline glorfindel
« Reply #115 on: May 15, 2019, 03:05:33 PM »
Those little things are brittle arent they? ;-)
I will have to make some more lol!!
« Reply #116 on: May 15, 2019, 04:52:30 PM »
Yes and they always has been when made from cast iron - don't know if you can do the same tempering as with hardening in order to improve matters ….  :thinking:
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #117 on: May 15, 2019, 06:04:38 PM »
You have access to a wire EDM. That is awesome. I’m actually a little bit jealous.  :Lol:
I enjoy seeing the engine come together.  :popcorn: :popcorn: :popcorn:
Offline glorfindel
« Reply #118 on: May 15, 2019, 07:00:40 PM »
I made 12, only 5 make it to the piston lol!!!!
I'll get better ;-)
Offline glorfindel
« Reply #119 on: May 15, 2019, 07:02:53 PM »
I'm blessed to have access to those fancy tool !!
It work great to cut the rings. Ut's the most precise tool we got, about +/- 0.00003
