Author Topic: LMS Black5 3.52 Gauge info please  (Read 1175 times)
Offline PJW
« on: December 23, 2018, 11:03:23 PM »
I am restoring a LMS Black5 3.52 Gauge and need to order a missing casting, can anyone help with the naming of this piece indicated on the attached PDF, thank you!
Old Guys Rule the Dark Side of the Shed!
Offline Zephyrin
  • near Paris, France
Re: LMS Black5 3.52 Gauge info please
« Reply #1 on: December 24, 2018, 07:58:42 AM »
they are the steam pipes for outside cylinders; a plain fabrication would do it if casting doesn't exist.
Offline michaelr
« Reply #2 on: December 24, 2018, 09:36:42 AM »
They are the cylinder steam pipes, I don't think you will get a casting for them as they are usually fabricated from brass a formed cover fitted to smokebox and running board.
Mike.
« Last Edit: December 24, 2018, 06:53:18 PM by michaelr »
Offline PJW
« Reply #3 on: December 24, 2018, 10:29:03 AM »
thank you both, better get started, Peter
Offline PJW
« Reply #4 on: December 24, 2018, 03:08:19 PM »
The boiler pressure gauge is missingI will have to buy one, does any one know what pressure this boiler will produce so I know pressure range of gauge I will need to obtain please???
Offline Stuart
  • Tilchestune UK
« Reply #5 on: December 24, 2018, 03:24:04 PM »
What does it say on the boiler Backhead should be stamped with the SWP
Strictly a guess mine was 80 psi
If you donít know you need to get it tested then have the gauge dead weight calibrated and red lined
Offline PJW
« Reply #6 on: December 24, 2018, 04:09:53 PM »
sadly I know nothing about loco's but I have just bought a 3.5" gauge one it has run but was partially stripped?? why?? and a few parts are missing, i am trying to restore it but I dont think I will run it, but want it right. I can see me coming back for help in the future. It would be great If I had a set of plans, sadly they are expensive.
I have had a great deal of help in the past and it a a great boon to have so many talented engineers to assist me & I thank them all.
Offline Steve F
  • Hornchirch Essex UK
« Reply #7 on: December 24, 2018, 05:26:13 PM »
Hi
If it's the LBSC Doris then the build articles are available so you may not need the plans. Have a look here http://www.john-tom.com/LBSC/Doris.zip
regards
Offline PJW
« Reply #8 on: February 19, 2019, 07:38:59 AM »
Thank you so much for the PDF file, it has been so useful. I did obtain the original set of drawings, but they are very fragile as they are approx 70 years old. The cab was complete bar the Pressure gauge which has been ordered, the missing dome has been made and also the shroud cover for the front pipes. It is looking better all the time. one day I would love to see it in steam, but that may never happen, sadly. I will attach a pic to show you all & looking at it the handrails down the side of the boiler would lift the profile a lot??
