Author Topic: building the Frisco Standard Model  (Read 31058 times)
Online steamer
« Reply #45 on: January 08, 2019, 10:02:14 PM »
I like gluing in supports between the webs im not machining to keep the crank from flexing.
You just wave a torch at it later on and the cyano lets go.  Clean up with Acetone.
« Reply #46 on: January 08, 2019, 10:12:04 PM »
Superglue will hold the packing rods well enough to handle spinning on the lathe?
Online steamer
« Reply #47 on: January 08, 2019, 10:16:02 PM »
Yup!!!   Think about it, when it's between centers, the lathe is squeezing on the packing.   the glue just keeps it there.  I size the packing pieces and cut them from bar stock and face to length.
« Reply #48 on: January 09, 2019, 02:39:08 AM »
Craig,
You're making good progress. Some great ideas guys, I think I'll file them away. I think when I made the Upshur I ground a 3/8 nut to fit and let the center's pressure hold it together. Val was an overhung crank.
« Reply #49 on: January 09, 2019, 03:30:40 AM »
Dang, that's lookin' real nice! Tell that ol' leg to take a break so you can get in more shop time!
 :DrinkPint:
« Reply #50 on: January 09, 2019, 03:38:27 AM »
Ah, good point! Physics works!   :ThumbsUp:
« Reply #51 on: January 10, 2019, 01:21:42 AM »
Dave, Chris, Art, Pete; thanks for your comments.  I’ll give you another option that I use for temporarily fastening the support between the throw webs for support… hot glue.  I’ve used it numerous times, easy to install and cleanup is a breeze.
UPS usually delivers to residences in my neighborhood at dark-30 but today the UPS delivery showed up mid-afternoon, so I got some work in after all.  That probably was as well because tomorrow is supposed to be C…..O…..L…..D and there probably won’t be any shop time.
After grinding this ½ inch shank down to 3/8th inch I got busy finishing the throw.  Didn’t take any pictures, so after I was all done, I caught-up with the photos, you’ll get the idea.
Cleaning up the left (center) throw
  Cleaning up the right throw
Working down to the final diameter
A little final sanding to remove a few tool marks
Next I’ll move on to the left-hand throw.
« Last Edit: October 17, 2022, 06:13:33 PM by Craig DeShong »
Online steamer
« Reply #52 on: January 10, 2019, 01:40:39 AM »
Looks awesome!!   Thanks for the tip   ill try that next time.
« Reply #53 on: January 10, 2019, 01:46:43 AM »
Very well done, that is quite a big part!
« Reply #54 on: January 10, 2019, 10:14:16 PM »
Dave, Chris; thanks for stopping by.  It is a large piece to be swinging in the lathe.  I’ll be glad when I have these throws complete and I can be working outside instead of inside the throws.  One little lapse of concentration and have the throw come around and strike the tooling and UGLY things will happen. :hammerbash:
I braved the cold North Carolina weather (yea- you guys in Canada are laughing yourself silly now :lolb:) and worked on the other throw.   It was pretty much the same procedure.
Here I’m milling out between the throw shoulders (stuck to the way I did the first one- if it ain’t broke, don’t fix it)
Finishing up on the mill
And the lathe work
« Last Edit: October 17, 2022, 06:16:20 PM by Craig DeShong »
« Reply #55 on: January 10, 2019, 10:46:03 PM »
Coming along well Craig!! Yes the temps were rather cool today. The shop heat pump is sure helping though.
Online steamer
« Reply #56 on: January 10, 2019, 10:48:33 PM »
Looking great Craig....going to single digits F here tonight...without the wind chill
« Reply #57 on: January 10, 2019, 11:26:55 PM »
Machining crankshafts makes your old heart go "pitter-patter", doesn't it!!! It was -28 C here today with the wind-chill. I had to go out and buy a new electric drill and get a different intake valve spring, and it certainly wasn't bikini weather.
Online steamer
« Reply #58 on: January 11, 2019, 12:08:04 AM »
 8)
« Reply #59 on: January 11, 2019, 02:56:39 AM »
Craig,
I have to ask, how far out is that lathe tool sticking out. It looks to be about 2 inches. The one lathe tool I have for that sort of thing I used on the cooling fins on Val, I needed .720 depth of cut to clear the corners of the cylinder, clears the tool by .03". A friend used the wire EDM to cut it .5 tall .25 wide blank. I should design on with radiused corners relieved in the center, for turning crank throws. Then when he has time on the machine he can make me a new one to use on a crankshaft.
