Author Topic: Pennsylvania A3 Switcher (Kozo)  (Read 48204 times)
Offline Kim
« on: October 19, 2018, 01:58:26 AM »
After I started the build, I wished I'd left space for an index.  Since I didn't, I'm adding it to the beginning of my intro post.The actual introduction starts right after the build index. Please skip up there if you don't want to read the index :)
Index of Kim's Kozo's Pennsy A3 Switcher Build:
Chapter 2: Tender Wheels
Chapter 2.1 - Tender Wheels - Reply 20
Chapter 2.2 - Tender Axles - Reply 105
Chapter 3: Tender Truck Frames
Chapter 3.1 - Journal Boxes - Reply 116
Chapter 3.2 - Journal Bearings - Reply 142
Chapter 3.3 - Columns - Reply 157
Chapter 3.4 - Bolsters and Side Bearings - Reply 170
Chapter 3.5 - Tie Bars and Arch Bars - Reply 201
Chapter 3.6 - Coil Springs - Reply 234
Chapter 4: Tender Frame
Chapter 4.1 - Side Sills - Reply 251
Chapter 4.2 – Front End Sill and Rear End Sill - Reply 262
Chapter 4.3 – Front and Rear Bolster - Reply 296
Chapter 4.4 – Drawbar Pocket and Drawbar - Reply 298
Chapter 4.5 – Front Steps - Reply 303
Chapter 4.6 – Step Brackets - Reply 323
Chapter 4.7 – Rear Coupler Pocket - Reply 329
Chapter 4.8 – Foot Board - Reply 342
Chapter 4.9 – Center Pins and Drawbar Pin - Reply 348
Chapter 5: Tender Tank
Chapter 5.1 – Tank Floor - Reply 421
Chapter 5.2 – Side Plates - Reply 447
Chapter 5.3 – Side Corner Members - Reply 463
Chapter 5.4 – Bottom Horseshoe Member and Top Horseshoe Member - Reply 475
Chapter 5.5 – Verge Board - Reply 480
Chapter 5.6 – Vertical Board - Reply 489
                       Vertical Board Revisited - Reply 507
Chapter 5.7 – Front Plates - Reply 503
                       Front Plates Continued - Reply 518
Chapter 5.8 – Top Plate - Reply 528
Chapter 5.9 – Rear Corner Member - Reply 546
Chapter 5.10 – Soft Soldering and Filing the Bottom - Reply 552
Chapter 5.11 – Headlight Baseplate and Headlight Base - Reply 573
Chapter 5.12 – Coal Stopper - Reply 589
Chapter 5.14 – Dummy Side Plates - Reply 599
Chapter 6: Tender Manhole
Chapter 6.1 – Mounting Plate, Manhole Plate, and Lug - Reply 613
                       Manhole Plate - Reply 619
                       Lug - Reply 629
Chapter 6.2 – Manhole - Reply 620
Chapter 6.3 – Manhole Cover - Reply 634
Chapter 6.4 – Hinges and Pin - Reply 637
Chapter 7: Steps and Handrails
Chapter 7.1 – Steps - Reply 641
Chapter 7.2 – Handrailing - Reply 644
Chapter 7.3 – Handholds - Reply 661
Chapter 7.4 – Handholds - Reply 673
Chapter 8: Hand Pump
Chapter 8.1 – Pump body - Reply 683
Chapter 8.2 – Plunger - Reply 710
Chapter 8.3 – O-Ring Retainer - Reply 712
Chapter 8.4 – Plug - Reply 724
Chapter 8.5 – Suction Valve - Reply 725
                       Suction Valve Screen Retainer - Reply 742
Chapter 8.6 – Link - Reply 731
Chapter 8.7 – Lever - Reply 746
Welcome everyone, to my introductory post for my new build of Kozo’s Pennsy A3 Switcher!
I’m sure this is no surprise to anyone, since I’ve been talking about it, asking questions about it, and doing some pretty serious planning on it for well over a year now.  But, this is my formal intro to my build thread.  So, if you’re too disappointed, please feel free to skip on past to the next post.  I promise not to be offended.
As an intro post, here is my obligatory photo of what I’m shooting for.  This is the cover photo from Kozo Hiraoka’s book “The Pennsylvania A3 Switcher”.
The final engine will be 38” long, 10” high, and 7” wide.  It is a  3.5” gauge, 1:16 scale (3/4” to a foot) model of an 0-4-0 Pennsylvania Switcher Type A3.  The drivers are 3.25” diameter and the cylinder bore is 7/8” with a stroke of 1-1/4".  It will have Walshaerts type valve gear, will be coal-fired with a running pressure of 100psi.  Engine plus tender will weigh-in at about 62 lbs.
So, this will be quite a monster for me!  More than double the size of the steam tractor I did. And a MUCH more serious steam project than I’ve taken on in the past.  But I’m ready and very excited for the challenge!  And isn’t that half the battle right there? (He says with naďve optimism :)).
With that lengthy introduction, let me now introduce you to my BOM spreadsheet.  Kozo’s book is amazingly complete and gives excellent instructions on all his fabrication techniques.  But!  It does not include a bill of materials!  So, what does any self-respecting anal-retentive engineering-type do?  Create a spreadsheet, of course.
Last Edit: July 20, 2020, 01:55:39 PM
I’ve attached my spreadsheet to this post.
If anyone is ever interested in doing this build, I would think having the BOM available would be helpful.  I went through the book, entered every piece of stock as specified by Kozo, broken down by section and part number within the section (and often sub-element of a part within a section).  It includes all fasteners, jigs and the sacrificial screws Kozo uses to hold parts together while silver soldering.  That’s the first sheet. Its labeled “A3 Switcher BOM” and has something like 850 unique lines.
The second sheet is the Materials List.  This has one entry for each type & size of material used and summarized the total number of inches (for bar, rod, hex) or square inches (for sheet material) that are needed for ALL parts using that type of material.  it has more than 350 lines, but only 260 something of them ended up being used in my final version of the BOM.
The actual materials listed are based on “My Material”, not on the type originally specified by Kozo.  He did almost everything with 360 Brass.  I substituted a lot of 1018 (CRS) or 12L14, or even Stainless in some places.  But I did leave Kozo’s originally specified material listed on the first sheet.  And someone could move to using that material if they wanted to.
The completion of my BOM spreadsheet took me almost a year of background work, so was no small task in itself.
Late last week I did an inventory of my stock on hand against this Materials List.  Then I entered that into the spreadsheet and it told me how much of what I needed to purchase.  After that, I went through the spreadsheet and did some more substitutions and combining of lines.  For example, if I need 1” of 5/16” brass, I’d look at changing it to 12L14 or if it needed to be brass (because it comes into contact with water) I would just combine it with the 3/8” brass.  I made some fancy columns to help me combine lines.  Not intuitive, but if anyone's interested I'd be happy to explain it.
Last weekend, I spent hours placing a big metal order.  I ended up going mainly with On Line Metals, and with Speedy Metals.  On Line Metals generally had better pricing on 1018, Stainless, and Brass, where as Speedy Metals had better prices on 12L14 and had a larger selection of sizes of 1018 than On Line Metals. Unfortunately, shipping from Speedy Metals is 2x more than On Line Metals because they are on the far side of the country from me. But I tried to get it all these two larger orders.  Shipping hurt, but it could have been worse!
And yesterday a bunch of my metal started showing up! This was the bulk of the order from On Line Metals.  Speedy Metals won’t arrive till next week.
After opening the containers and comparing to the shipping invoice (all correct, BTW) here’s what I’ve gotten so far.  And this is probably about two thirds of what I ordered.
In addition, there’s a bunch of fasteners, non-metal parts and various new tools I’ll need for this build.  I also kept a list of tools I needed to order for this build.  That’s also one of the sheets in my spreadsheet.  Here’s what’s arrived from that list so far:
Kozo uses a TON of random sized threads in his build.  He uses 5-40 and 5-44.  He uses 8-32 and 8-36.  I considered standardizing on taps I already had but decided it would be fun to get some new taps anyway.  And I figure he had some reason for using the finer pitched threads, so why not follow his lead, since I’m game for buying another half dozen taps and dies :)
Then one other thing I bought for this build, and am just a little too excited about, is a set of letter & number punches.  I have a very cheap set (cost $10 at a harbor-freight look-alike place) but they are so cheap that they make poor letters. And any of them I’ve used more than once are already getting so flat it's hard to read what gets punched.  This is a set of CH Hansen Letter and Number Punches.  It cost significantly more and had quite good reviews with people saying the punches held up under actual use.  And I’ll say they look much better than my cheapy punches.
Kozo recommends punching identifying numbers & marks into each piece so that you can get it re-assembled back into the same spot it was designed for. I'm going to try and do that too.
So, wish me well on my next multi-year voyage in the world of Steam Model Engineering!
Thanks,
« Last Edit: July 27, 2020, 01:18:34 AM by Kim »
« Reply #1 on: October 19, 2018, 02:27:37 AM »
This is exciting Kim!!!  I am along for the ride as always!!
« Reply #2 on: October 19, 2018, 02:30:31 AM »
Ooohhh!  Excellent!!!
Great prep work, and nice pile of future swarf. These big projects seem too daunting at first, but one part at a time and its a lot of fun to see come together.
Really looking forward to seeing you go on this one.
Offline Flyboy Jim
  • Independence, Oregon
« Reply #3 on: October 19, 2018, 03:21:24 AM »
Kim..........this is going to be another great build thread to watch!  :ThumbsUp:
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #4 on: October 19, 2018, 03:27:08 AM »
 :whoohoo: :popcorn: :popcorn: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :whoohoo:
I don't know whether to laugh or cry.  I've had that book on the shelf right above my desk for over 10 years.
As I age I think of selling it on.
Offline Kim
« Reply #5 on: October 19, 2018, 05:25:12 AM »
Thanks guys, it will be great having you along for the build!
Pete,
You should start your own Pennsy Switcher now!  We could do parallel builds!  Wouldn't that be fun?
I'd love to see you do that :)  :ThumbsUp:
« Reply #6 on: October 19, 2018, 08:01:04 AM »
Hello Kim,
Well I'm on board too, this should be another great ride.  :popcorn:
Have a great day,
« Reply #7 on: October 19, 2018, 10:21:23 AM »
 8)
I do parts lists for my engine as well but I decided it was best not to write down how much it cost  :paranoia: I prefer to just tick that I have it available
I also like to mark off the date I complete each part - it shows how quickly the engine came together (or how slowly/how long the build gaps were  :facepalm2: )
  • Sřften - Denmark
« Reply #8 on: October 19, 2018, 12:40:05 PM »
Hello Kim
I must admit that I really haven't really commented much in your excellent tractor build (there has been plenty others, so not much need).
I do make BOM for the products we make at work, but - WOW - what a list and amount of work you have put into this one  :praise2:
I will certainly follow this build too  :cheers:  :popcorn:
Best wishes
« Reply #9 on: October 19, 2018, 01:59:56 PM »
Very cool Kim, I will be looking forward to following your progress.
« Reply #10 on: October 19, 2018, 02:03:17 PM »
Off to a great start Kim. I'll be riding along on this one also.
Whiskey
Offline Kim
« Reply #11 on: October 19, 2018, 02:44:34 PM »
Thanks everyone!
Yeah, I'm pretty pumped about this one.   :cartwheel:
It did give me pause; putting the cost of materials in the sheet.  But it also helped me make some material trade-offs.  Some of the columns I've hidden were a comparison between a "Mostly Brass" model and my hodge-podge version. I hid the columns because I stopped keeping it up at some point and I didn't want to spend the time to fix it.  I figure I saved about 35-40% in cost by avoiding gratuitous use of brass :).  Don't get me wrong - there will still be a lot of brass!  But dramatically less than Kozo uses!
Offline Florian Eberhard
« Reply #12 on: October 19, 2018, 06:40:22 PM »
Hey Kim - i am checking in too!  :popcorn: :popcorn: :DrinkPint:
I imagine Kozo used brass because it is easier to machine than steel. Especially with small hobby machines. But there's nothing wrong about using other materials if it makes sense or if it doesn't need to be brass.
Now i guess we have to wait for your first swarf pictures.  ;D
Florian
Offline Kim
« Reply #13 on: October 19, 2018, 08:26:27 PM »
Thanks Florian!
Yeah, it shouldn't be too long before I start making Pennsy Switcher swarf.  Still a bit more on the steam tractor to finish up, but that's getting every so close!
Thanks,
« Reply #14 on: October 19, 2018, 08:55:03 PM »
Swarf!
Swarf!
Swarf!
And tractor running video too, of course!   :Lol:
