Author Topic: Train In a Bottle  (Read 3183 times)
Offline sbwhart
  • Live Long and Prosper
Train In a Bottle
« on: October 06, 2018, 06:37:03 PM »
I've just made this novelty for my youngest train enthusiast grandsons 4th birthday.
 :D :D :D :D :D :D :D :D :D :D :D
Stew
Re: Train In a Bottle
« Reply #1 on: October 06, 2018, 06:46:31 PM »
Hello Stew,
He should love that for the rest of his life, good job.
Have a great day,
Offline JC54
  • Grantham, Lincolnshire, UK
« Reply #2 on: October 06, 2018, 06:49:34 PM »
That is brilliant Stew.... I am completely baffled, any chance of some built pics please? :shrug: :noidea: :old: :DrinkPint: JC
When the Fun Stops,, Stop!
« Reply #3 on: October 06, 2018, 07:35:43 PM »
Love it Stew!! Thanks for the picture.
Offline sbwhart
« Reply #4 on: October 06, 2018, 08:31:08 PM »
I was taught the method by an old sailor who was a dab hand at putting ships in bottles:-
 :Lol:
This is some of the materials and tools (balsa wood and dowelling)
First you need to know the inside and neck sizes of the bottle the neck is easy mine was 20mm but for the inside you need to make a little gadget I used a coffee stick for mine
Just insert it into the bottle and find the smallest size and mark the stick remove from the bottle set it back on the mark and read off the size mine was 40mm.
Next mask off the neck of the bottle as you don't want to get it all glued up.
Then paint the bottom with PVA adhesive and pour in some oo gauge track ballast shake the bottle so it stick to the glue poor out the access and put to one side for the glue to dry.
If you haven't figured it out yet you make the train in sections the first bit is the track made from coffee sticks and balsa I built it up in a coffee stick frame frame held down with drawing pins, just make sure the width will go through the neck and the length will fit the base mine was 120mm long, I also stuck the wheels as well
Next make the other bits for the train all the time checking they will got through the neck and fit in the bottle.
I just painted the parts with felt tip pen.
To assemble  the bits in the bottle you need a pair of long nosed tweezers a pin stick in the end of a bit of dowelling and a length of wire with a flat end I made mine form a metal coat hanger.
Put a blob of bostick adhesive on each sleeper and using the tweezers insert it into the bottle use the wire to press it down let the adhesive set before you put in the next bit.
You assemble the train from the back push the pin into the part, apply adhesive put it in the correct position and use the wire to push it off the pin and manoeuvre it into the correct position.
The last part to be assembled is the boiler and cab.
Job Done
Stew
« Last Edit: October 06, 2018, 08:38:48 PM by sbwhart »
Offline Stilldrillin
« Reply #5 on: October 06, 2018, 09:57:49 PM »
Now...... That's clever!  :ThumbsUp:
Well done, Stew!  :praise2:
David.
« Reply #6 on: October 06, 2018, 10:58:06 PM »
Excellent!!
« Reply #7 on: October 07, 2018, 01:14:53 AM »
Very cool!!
« Reply #8 on: October 07, 2018, 07:40:28 AM »
Wonderful  :praise2:  :praise2:
Offline JC54
« Reply #9 on: October 07, 2018, 07:15:56 PM »
Many thanks Stew for explaining. I had visions of shop elves in potholing gear. :Jester: :old: :DrinkPint: JC
Offline CookieCrunch
« Reply #10 on: October 14, 2018, 10:36:29 AM »
Absolutely love it.  Brilliant job.
