Author Topic: Bob Herder's Meyers side shaft hit and miss  (Read 16169 times)
« on: September 03, 2018, 04:03:37 PM »
I bought this casting set some years ago at Cabin Fever.  I didn’t start building it right away and that winter a friend of mine, Gordon Miner, was looking for a project.  He mentioned to me that he was thinking about building this engine, but was bemoaning pay the shipping.  Since I had the kit and wasn’t planning on building it in the immediate future I offered it to him.  He built the engine and did a magnificent job; it runs like a sewing machine.  If mine runs as well, I’ll be elated.
Some years passed, and last winter, while at Cabin Fever, I bought the kit AGAIN.  It cost me an additional $10 since the price had gone up (reminder- I need to pump Gordon for the extra $10 :LittleDevil:).
With the Root and Vandervroot finished; I thought it might be fun to get started on this project and see how well along I can take it before the winter sets in.  I can’t stand being idle.
This “kit” is prints and castings, offered by Bob Herder of Califon, NJ.  USA.  It models a 1905 Myers “hit and miss” engine with side shaft and ignitor.  It builds a beautiful model; and if you’ve been to a modeling expo here in the States, you’ve undoubtedly seen one.  The full size engine weighed 850 LBS and was a 2 HP engine.  The drawings do not identify the scale of this model but for general size, the flywheels finish to 8 ½ in. diameter.
You may remember me stating that I keep my models in my Daughter’s vacated room, now that she’s married and moved away on her own.  You may also remember me stating that she left her childhood stuffed animal collection behind.
Therefore, facing this before, it was no surprise that when I entered her room to retrieve the castings was presented with this:
Again, Sirus has been busy with his communications “across the pond”. :noidea:  Fortunately, I was informed that the current “casting fondling” was merely being performed to keep them “safe”. :ThumbsUp:  (With a little “special coating” appearing on a few of the cast iron pieces I’m not sure how much “fondling” has been going on :lolb:), but I was happy to be allowed to retrieve them.
Before I start cutting metal, I thought I’d give you a good view of what is delivered.  With the “kit” you are supplied these castings plus eleven hand drawn prints and several pages of photos of the more intricate parts and assemblies.  I can’t see me having problems envisioning how all this goes together because if I do, I just need to drive across town and visit Gordon to inspect his completed model. :ThumbsUp:
First however, a thorough study of the drawings is in order. :happyreader:
« Last Edit: April 27, 2019, 02:01:44 AM by Craig DeShong »
Re: Bob Herder's Meyers side shaft hit and miss
« Reply #1 on: September 03, 2018, 04:25:45 PM »
Nice set of castings  :)
Do you have any pictures of the finished engine so we know what it will look like?
You need to do your own casting fondling Craig, complete with the drawings and measuring devices don't let anyone else claim they have done it for you :hellno:
I am aware Surus is busy trying to make friends across the pond as he has tracked down sets of castings for a Wall C-601 4 Cylinder Side Valve and a Wall C-605 30cc single Cylinder engines without drawings: Now he is pestering everyone trying to find the required set of drawings :facepalm:, once he has found them he will expect me to go and acquire the castings for him  ::)
P.S. Is this the one?
<a href="https://www.youtube.com/watch?v=m8OuiR1chWo" target="_blank">http://www.youtube.com/watch?v=m8OuiR1chWo</a>
« Last Edit: September 03, 2018, 04:30:27 PM by Jo »
« Reply #2 on: September 03, 2018, 05:00:22 PM »
Jo.  Yep, that's the model.  And...  I ALSO do my fair share of 'casting fondling"  :)
« Reply #3 on: September 03, 2018, 06:46:53 PM »
Craig, I have seen one of these and it's a very interesting engine. I especially like the side cam mechanism for the igniter. Looking forward to this one.
« Reply #4 on: September 04, 2018, 04:34:42 PM »
Hi Craig
Nice engine, and its good to see you off onto a new project, I'm looking forward to watching this one take shape.
« Reply #5 on: September 05, 2018, 12:11:22 AM »
I started on the base today.  I’ve looked over these castings and I must say that the quality in them is some of the best I’ve had to work with.  If you’ve worked with castings for a while you know that sometimes you really have to work to get the intended part from what you’re given.  These castings are not only well cast, but there is ample material provided so that all machined surfaces can be readily attained.
Drawing 1 describes the operations to be performed on the base, might as well start there.
As you well know, the first step is to get the bottom of the base smooth and even so that the casting will sit flat on the mill table without rocking around.  My method is to shim some good anchor points until it doesn’t rock;  then a test indicator will, more or less, show that the bottom is sitting parallel to the mill table.  Then I just run around the surface with an end mill to mill the bottom of the base flat.
While I have the base square and upside-down, I might as well go ahead and drill the mounting lugholes.
I always mount these bases on a squared plate.  I’ll be mounting this engine base on angle plates to drill the various holes required and placing the base on a squared plate is a good way to assure that my set-ups will be square and repeatable in the various orientations I’ll require.
Measuring up from the mounting plate the required distance, the crankshaft journal supports are machined.
Then I can bring that measurement forward and mill down the cylinder mounts
While I have this measurement set-up, I might as well drill and tap the crankshaft cap journal mounts as well as the cylinder mounts.
With the 80 LB. (pant, pant :'() vice back on the mill I’ve started work on the crankshaft journal caps.  I need to finish these and attach them to the base before I can bore the hole through the journals for the crankshaft.
I’m drilling the cap mount holes.  I’m doing this with the same setup as the milling operation so the holes are square to the milled surfaces.
A good place to stop for today.
« Last Edit: April 27, 2019, 02:13:52 AM by Craig DeShong »
« Reply #6 on: September 05, 2018, 12:18:08 AM »
I've always enjoyed 'hit and miss' engines. I'm looking forward to this one.
« Reply #7 on: September 05, 2018, 12:22:38 AM »
Off to a great start Craig. You got a lot done!! Nice to hear the castings are of good quality too. That helps a lot!!
Offline propforward
  • MN, USA
« Reply #8 on: September 05, 2018, 03:37:57 AM »
Fantastic - what a great and detailed build log. Lots to learn and enjoy here - I will be following along.
Forging ahead regardless.
« Reply #9 on: September 05, 2018, 07:16:39 AM »
Off to a good start  :)
Did you see my "roller skate"? I Picked up a Motorcycle hydraulic scissor lift table with wheels and have been using that to move my very heavy tooling on and off the mill table e.g. https://www.ebay.co.uk/itm/302827723682. They don't seem to be as available as they were a couple of years ago  :noidea:
« Reply #10 on: September 05, 2018, 10:35:50 PM »
Bill, Dave, Zee, Stuart, Jo; thanks for your comments.  Thanks to others that are silently following along.
Jo- I HAVE a hydraulic table :); I’m just to dang stubborn to dig it out and use it :-[.  To date it’s not that tough lugging the vice, turn tables, diving heads, etc. around yet but… the time is coming when I’ll succumb and dig the hydraulic table out.  Till the I’ll just whine like a three year old while I carry them :lolb:.
I spent the afternoon in the shop, making black talcum powder :Jester: (while working on this engine).
Here I’m milling the crankshaft journal pockets for the correct crankshaft width and journal width.
I’ve mounted the base on an angle plate and have made the first pass at drilling the crankshaft journals.  I’m merely trying to remove material at this point.  I’ll use a boring bar to get the crankshaft journals “true”.
I didn’t want to drill these holes too large, lest the drill wander and my boring bar not be able to form true holes.  Here I’m using a thin boring bar; a bit of bending taking place but once again I’m just trying to remove stock.  In the next picture I’ll be sizing the holes to the correct diameter.
With the journal holes at a diameter my long, rigid boring bar can clear, I’m making a final pass.  This should assure me that these two holes are of the correct size and alignment so that the crankshaft should fit nicely with no binding.
Since I have a ¾ inch ream I bored the holes just a few thou. undersize and now I’m using my reamer to establish the correct diameter.  If I didn’t have the ream I would have bored them to size but the ream makes it easier to hit the target size of .750 inch.
I usually make split bearings at this point.  The “kit” however came with these oilite bearings; might as well use them.  With the crankshaft journals the correct diameter I’m pinning the oilite bearings to the journal pockets.
Now with the journal caps in place I’ve drilled the oil holes so the crankshaft journal bearings can receive lubrication.
« Last Edit: April 27, 2019, 02:25:31 AM by Craig DeShong »
Offline Steamer5
  • The "Naki" New Zealand
« Reply #11 on: September 05, 2018, 10:51:30 PM »
Hi Craig,
 Great build log & good progress. Like the setups & the explanation of the whys & hows
Cheers Kerrin
« Reply #12 on: September 06, 2018, 12:37:49 AM »
Very impressive work, great build!
 :popcorn: :popcorn: :popcorn:
« Reply #13 on: September 06, 2018, 01:07:39 AM »
Another productive day in the shop Craig. Very nice work too.
« Reply #14 on: September 06, 2018, 10:36:31 PM »
Kerrin, Chris, Bill; thanks for your comments.  Thanks also for those silently following along…
I’ll need to set the engine base aside for a while.  I need a long reach drill bit to drill the forward boss on the base for acceptance of the side shaft.  While I’m awaiting delivery, I’ll start on the cylinder.
After studying the drawing for a while I decided to start by milling the mounting flanges.  These need located and milled so that the cylinder bore will be aligned with the center of the crankshaft.
While I have this casting located and mounted in the vice I’m going to plane the sides of these mounts.  This will allow me to accurately re-locate the centerline of the cylinder.
Drilling the cylinder mounting holes.
I’m not really excited about this breakout on the cylinder casting :o.  I’m hoping I have enough material to mill away this break because it’s at the rear of the cylinder at a very obvious place.
A little fitting is required for the cylinder casting to fit into the frame receiver.
Here I’m removing the superfluous material so the cylinder casting will set into the base casting.
Here I’m setting up for boring the cylinder.  My boring bar is JUST long enough to do this with one continuous bore. :)
I’m getting a bit of chatter and movement as the boring progresses.  By running the mill in back-gears at a speed of around 60 RPM the chatter has disappeared.  Lighter cuts (under .025 inch) pretty much eliminate the movement.  Fortunately my mill has power down feed, so it’s a matter of setting up the cut and walking away for around ½ hour till the pass is complete.  It's going to take hours to achieve the 1.5 inch diameter bore, but with the setup I'm using, I'm assured of the bore being aligned with the crankshaft.
« Last Edit: April 27, 2019, 02:35:26 AM by Craig DeShong »
