Author Topic: Drawings  (Read 7015 times)
Offline freko16
  • Jr. member
Drawings
« on: February 22, 2018, 01:20:03 PM »
Hi, I am venturing into the black art of boiler making I want to make a horizontal 4.5 inch gas fired boiler , my efforts to find any sort of information - drawings etc has been hopeless, can anybody help. Regards Ken.
Offline MJM460
Re: Drawings
« Reply #1 on: March 06, 2018, 07:25:46 AM »
Hi Ken,
I missed this post when you posted it and only found it yesterday.
Welcome to the forum.  How about introducing yourself on the introductions board so we know a little about you and your interests.
A single dimension is not a very helpful description of a boiler, so it is quite hard to know what sort of help you are seeking.
However a good start, which will hopefully lift you out of the black art feeling, would be to buy and read K. N. Harris' excellent book on model boiler making.  I assume it is available from one of the normal suppliers of modelling books.  I would also recommend Alex Weis' book on miniature boiler making for gas firing, it is sold by Camden in electronic form.  They also have other books you might find interesting.
The cylindrical shell section of a boiler is pretty straightforward.  It is the openings for filling, steam outlet, and safety valves that involve more science, along with the design of staying systems for the ends of the boiler and for any flat firebox surfaces.  And you will need a safety valve and perhaps a level glass.  A pressure gauge is also helpful.
Another important source of information is the inspector at your local club.  Join up, meet like minded friends and check the requirements for design approval, inspections during construction and pressure testing.  This is important even for published designs, especially if they are older than the current series of model boiler codes.  If you don't do this first, you will probably find you can't display your efforts in public.  But more importantly, you won't be sure that you have covered all the necessary issues for a safe boiler, and remember, you will probably be the closest if anything goes wrong.
I mentioned the codes above, they are another resource that will help you, but not easy to read without some prior understanding.
Hope this helps give you a start.
« Last Edit: March 06, 2018, 07:36:17 AM by MJM460 »
Offline steamboatmodel
Re: Drawings
« Reply #2 on: March 10, 2018, 02:41:37 PM »
Hi Ken,
Here is a link to,
K.N Harris's book Model Boilers and Boilermaking.
(This one is almost considered the Bible among Boiler Makers)
Found online PDF copy:
http://www.fastonline.org/CD3WD_40/JF/424/19-422.pdf
This is from a book list I have on RC groups forum.
Gerald.
Re: Drawings
« Reply #3 on: March 10, 2018, 06:45:33 PM »
hi, don't forget to make all the bushes from bronze....never use brass....dezincefication  !!!!!!1. also get an original  Harris book rather than a reprint that has photocopied photos rather than original photos !!!
 Willy
Online steamer
Re: Drawings
« Reply #4 on: March 10, 2018, 06:48:24 PM »
There are some good. Oiler designs posted on this forum that comply with code and work.....id check them out first before designing your own
Re: Drawings
« Reply #5 on: March 14, 2018, 05:29:30 PM »
Always get a couple of proven designs under your belt, before working on your own design. Work through the math on the proven design so you know how it goes when you do your own. When you do your first design make it a conservative one, lots of time to do the flights of fancy after you gain some experience. No mater how safe the design is on paper always do a proper Hydrostatic test.
Gerald.
Ps I have a list of books on RC groups boat section under steam that may help.
https://www.rcgroups.com/forums/showthread.php?1226384-Books
« Last Edit: March 14, 2018, 05:33:06 PM by steamboatmodel »
Offline John Richard
  • Jr. member
Re: Drawings
« Reply #6 on: June 29, 2019, 12:46:09 AM »
This is a video of my first copper boiler, designed and built recently by me :- <a href="https://www.youtube.com/watch?v=a7nZ0zwbGEs" target="_blank">http://www.youtube.com/watch?v=a7nZ0zwbGEs</a>
It has 84 flue pipes and a super heater.  It contains 1.5 litres of water and is both gas and coal fired.  It was built under the supervision of our club inspector and now has a boiler ticket.  It is primarily used to test both steam pumps and injectors that I periodically make and maintain for club members.
Re: Drawings
« Reply #7 on: June 29, 2019, 01:42:45 AM »
Hello John,
Just watched your video and really enjoyed watching the Boiler in action and liked all that steam. I left you a comment and a  :ThumbsUp:
Have a great day,
Offline TerryWerm
Re: Drawings
« Reply #8 on: June 29, 2019, 02:54:58 AM »
Nicely done John. She steams nicely!
Terry
Making chips when I can!
