Author Topic: Pass the JB Welld Please Ramon!  (Read 3405 times)
« on: February 10, 2018, 08:22:09 PM »
Oh Bother, that was not meant to happen :-[
Re: Pass the JB Welld Please Ramon!
« Reply #1 on: February 10, 2018, 08:32:15 PM »
Ouch !!   :facepalm:
I feel your pain
« Reply #2 on: February 10, 2018, 08:35:58 PM »
Yikes!
And I bet 'Oh Bother' was not the direct quote...
Offline Ramon
  • Suffolk in the UK
« Reply #3 on: February 10, 2018, 09:09:10 PM »
I don't think so Jason - even I know when I'm beat  :D
Looks like you caught a crab on the brass? Now how you feel there all to well. Time to start over I guess ..... Commiserations
Ramon
« Reply #4 on: February 10, 2018, 11:25:30 PM »
Yes it was. But not to you.  ;D
I appreciate shots like this. It helps us newbies.
Online b.lindsey
« Reply #5 on: February 10, 2018, 11:34:16 PM »
That hurts to look at it Jason. Definitely a bummer!!! We've all been there though.
« Reply #6 on: February 11, 2018, 12:17:38 AM »
That iron looks to be very coarse grained. Much more than I think it should be...
« Reply #7 on: February 11, 2018, 08:05:35 AM »
Well if it helps others I will tell what factors caused it.
To start with I probably had a bit more than I should out of the vice as I wanted to see that the drilling at the far end of the chest to guide the vale rod did not wander. I did not disturb the work for the next op.
I had intended to screw the turned gland onto the end of the part and cut the "oval" shape in both parts as one but ended up doing the chest first which I did lowering the head and stopping when the DRO read 3.0mm. which went fine.
I then turned up and drilled the gland using the incremental DRO setting so I could go back to the chest and not have to ctr it up again. So screwed gland onto chest and started cutting but this time as I did not have to stop the cut at a specific height I used the quill feed.
Probably got a bit greedy and feed down to fact, cutter dug in and pulled the quill down and bang.
As Pete spotted it was not cut from a known piece of CI bar but liberated from an old York Multigym weight and was not as fine a grain, infact I also found a flaw in the iron as it was machined so should have probably binned it then. Though the break was not across the flaw. You can see it on the far side of the cavity but I thought it would make for a more authentic" casting" :mischief:
« Reply #8 on: February 11, 2018, 02:00:17 PM »
Hi Jason , sorry to see this happened... when i drilled my steam chest through the opening for the valve spindle, to keep the drill from wandering i always insert a piece of perspex in the opening ...I found this to work quite well !!
« Reply #9 on: February 11, 2018, 04:26:18 PM »
Thanks Willy, I did see that in your earlier post, I usually use  along series ctr drill but the valve rod on this engine is 2.5mm and my smallest drill 1/8".
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #10 on: February 11, 2018, 05:33:18 PM »
That's a pity Jason :-(
I wonder if it would be safer machining the valve rod detail before milling out the centre cavity ?
Just as a matter of interest what engine is it for ?
« Reply #11 on: February 11, 2018, 05:39:24 PM »
There is a risk that a long 2mm drill will wander drilling a deep (48mm ) hole so 6 of one and all that.
It's for the next 24mm bore one, teaser pic in the Robinson reject thread a few days back.
« Last Edit: February 11, 2018, 05:43:52 PM by Jasonb »
Offline Gas_mantle
  • North Yorks - UK.
« Reply #12 on: February 11, 2018, 05:58:18 PM »
Thanks, that's an attractive looking engine. I hadn't seen that posting.
