Author Topic: Talking Thermodynamics  (Read 133616 times)
Re: Talking Thermodynamics
« Reply #1110 on: January 11, 2019, 03:19:04 AM »
Hi MJM,  thanks for the info.......
willy
Offline MJM460
« Reply #1111 on: January 14, 2019, 08:39:36 AM »
Hi Admiral DK, thanks for joining in once again.  It’s interesting to see the diverse uses for these devices arising once they become available.
Hi Willy always glad to have a reason to talk about the science and physics that keeps things turning.  There has been a lot of progress since those early experimenters discovered strange effects at the junction of dissimilar metals.
« Reply #1112 on: February 10, 2019, 07:42:48 PM »
Hi MJM, just a quick digestion question from my hospital  bed. i missed a hot meal so they gave me some frozen sandwiches, They were sealed in plastic bags and i was wondering if they would get up to ambient quicker if they were removed from the bags ??? getting better slowly....
Willy
« Reply #1113 on: February 10, 2019, 09:56:23 PM »
Hope the date on those was 2019, not 1919....
You must be doing a bit better to be asking thermodynamic questions! Keep that up!
Offline MJM460
« Reply #1114 on: February 11, 2019, 12:28:55 AM »
Hi Willy, good to see you thinking about food and thermodynamics again, you must be on the mend.
As usual the question is a bit more complicated than it looks.  The plastic film makes a very thin insulating layer, and adds film coefficients for each side of the plastic.  Then, the air inside the wrap is somewhat restricted for convection.  I assume they are not vacuum packed.
The rough surface of the exposed bread has more surface area than the smooth plastic film, so that would help if unwrapped.  But the generally dry hospital air might make the sandwiches dry out while warming, so taking more time might not be the worst.  If they are like hospital sandwiches here, they don’t need drying out!
All in all, I wouldn’t want to predict the outcome on theoretical grounds, easier to determine by experiment.  You have the time, so perhaps one of your visitors could bring in your thermocouple probe and meter, and you could conduct the experiment, including the taste testing.  I am sure the nurses would let you use a sterile wipe to clean the probe before using it for a food application.  They would probably prefer that to your having someone bring in some saws, files and material for the next bit of your engine.
« Reply #1115 on: February 11, 2019, 06:43:16 PM »
thanks MJM, yes there are a few variables as taste and texture come into it....next time i come into hospital that will be first on the list !!!!   except they wright down everything you bring !!!
« Reply #1116 on: February 19, 2019, 08:25:00 PM »
Hi MJM, I was thinking about a telly programme that i saw 20-25 years ago that was about heating water by using the vibrating water hammer effect.  somebody discovered that the pipes got warm when a water hammer started up. the programme then went on to show in the USA a fire station using electric motor induced water hammers to produce all their hot water, ...Was i dreaming or hallucinating ?and did anything become of it ??   would love to know about the physics behind this !!! and did it come to anything ?
Willy
Offline MJM460
« Reply #1117 on: February 20, 2019, 11:37:04 AM »
Hi Willy, it sounds like you are feeling more like your normal self.  Keep it up.  That pneumonia can knock you around quite a bit for such a tiny bug.
Water hammer basically comes from the energy that has to be dissipated when you quickly stop a moving mass of some basically no compressible fluid.  You will remember that a moving mass has momentum, or even zero momentum if it is at rest, and it takes energy to change that momentum.
You may not be so familiar with the basic fact that to change the magnitude of momentum requires a force, and the magnitude of the force is calculated from the change of momentum per unit time.  From this calculation it is easy to see that if you quickly stop a moving body you get a large force.  The force necessary to stop a moving car in a very short time is enough to severely damage the car.  If you are unfortunate enough to be in that car, the seat belts have to apply enough force to stop you before you hit the windscreen, and that force is enough to damage you, but if the seat belt stretches just a little, it can double the time it takes to stop you and literally cushion the blow.  But the windscreen stops you very quickly, with the inevitable result.
Similarly if you have a pipe line of water moving at some velocity, and you suddenly stop the flow with a valve or what ever, the momentum of that column of water has to be changed by the valve plate, and as water is nearly not compressible, the whole column stops very quickly, requiring a large force, and that is the cause of the familiar water hammer description of the noise.   The energy of that moving column has to be absorbed, and is eventually dissipated as heat.
The water hammer that I have come across can be quite damaging, so the usual effort is put into preventing it by accumulators with a gas cushion that slow the rate of change, so reducing the maximum force, and preventing the damage.  The sudden compression of that gas cushion will cause it to get hot.  However, just how you would set up a system to continually produce water hammer and absorb the energy directly into heat, I am not sure.  Nor am I sure if this could be done with great efficiency.  I suspect it must involve gravity, as the efficiency of fuel powered devices to keep accelerating the column would likely make the system uneconomical.  I have not come across any such system, but the energy is there for those ingenious enough to work out how to harness it.
Perhaps in a district water supply system, there is a point where an air cushion accumulator experiences frequent enough water pressure surges due the velocity changes as consumption varies through the day, to produce useful heat.
Perhaps someone else had heard of it and can add something to the discussion.
But we really want to know how to use that energy in an engine to do useful work before it is eventually dissipated as heat.
« Reply #1118 on: February 21, 2019, 12:31:05 AM »
Hi MJM, thanks for that and i'm sure i saw this programme on the TV though...been trying to look it up on the web,...but to no avail....
willy
Offline MJM460
« Reply #1119 on: February 21, 2019, 10:02:12 PM »
Hi Willy, you probably did see it.  It would be interesting to know a bit more about it.
These questions tend to keep the sub conscious ticking over, and the more I think about it, I think gravity has to be involved, along with some consumption pattern that makes it possible to set up a system.  I was thinking of a resonant frequency that made it simple to keep the hammer pulses going, but, while that increases the amplitude, it does not increase the energy available, so is easily damped down if you start absorbing some of the energy as heat or in any other manner.   So the basic requirement is a continuing stream of pulses without expensive energy input.  That could potentially occur in a gravity system.
Resonance requires regular pulses, but resonance is not necessary if there is a continuing stream of pulses, or sudden flow changes, but my imagination has not come up with anything yet.
« Reply #1120 on: February 27, 2019, 12:50:45 AM »
Hi MJM. Just read your post... I missed it last week ,sorry about that.  Would it be possible to type in various significant phrases that might bring something up on the web ??.  still not feeling too hot yet just taking it easy for now.. Thanks
Wily
Offline MJM460
« Reply #1121 on: February 27, 2019, 08:37:00 AM »
Hi Willy,
You could try “harnessing water hammer”, or “energy from water hammer”.  Such searches are not my strong point, perhaps someone more practiced will chime in with some suggestions.
One example I have thought of is a water pumping device sometimes used on farms with a running stream.  It basically regularly stops the flow suddenly, and the pressure surge due to the water hammer pushes water through a check valve and actually pumps some water above the stream level into a tank without using a pump.  They are a bit hard to understand, and I can’t remember how the cycle is initiated and maintained, but it might turn up in your search.
Hope you are feeling much better,
« Reply #1122 on: March 26, 2019, 02:17:59 AM »
Hi MJM,  I have been watching a video about model aeroplane glow plug engines. I notice that to start them a battery is used to cause initial detonation, however when the battery is removed the engine still operates !! i was wondering about the thermodynamics that enables this to happen ...and how big an engine could one build using this technology ??  I am still not 100% and am having to catch up with the allotment and things.
Willy
« Reply #1123 on: March 26, 2019, 02:20:17 AM »
The little wire coil inside is made hot by the battery. Once the engine starts, the combustion heat keeps the coil glowing.
Offline simplyloco
  • Firstly the Stuart Beam, now it's the Big Time!
« Reply #1124 on: March 26, 2019, 09:32:35 AM »
Hi Willy,
SNIP
We used these -not very often!- in my combat engineering days. Very wasteful but they work!
