Author Topic: Bugatti Typ 50 1/4 Scale model  (Read 47548 times)
Online sco
Re: Bugatti Typ 50 1/4 Scale model
« Reply #285 on: December 06, 2018, 12:56:41 PM »
Great work Michael.  The tool post grinder - any more pictures of that, what you use it for etc.
Simon.
Ars longa, vita brevis.
« Reply #286 on: December 06, 2018, 01:50:21 PM »
Michael,
The new one piece Corian spark plugs look great.   :ThumbsUp: :ThumbsUp:
What type of coil are you now using? Do you know the output voltage? Some auto coils produce too high a voltage for our miniature spark plugs, which can make the plugs fail prematurely.
Please post the results of your tests and any developments
« Last Edit: December 06, 2018, 02:28:58 PM by Vixen »
« Reply #287 on: December 06, 2018, 05:21:30 PM »
I listened to a talk from Rollie Gaucher,  ...of Rollies Dads lathe alignment method fame.   He talked about making spark plugs using corian but its expensive    his comment was to bring a couple of models to the countertp shops, and theyll usually get so excited that theyll give you some off cuts for free.
Offline michelko
« Reply #288 on: December 07, 2018, 09:15:14 AM »
Mike,
at the end i was using an old Bosch Coil i had on the shelf. No idea what voltage it delivers.
In germany Corian is not realy expensive. On Ebay you can get rest pieces for a couple of euros.
Offline michelko
« Reply #289 on: December 10, 2018, 03:01:33 PM »
So i did some calculations and the actual CR should be 5,95:1.
What do you guys think, is this to high? Will the engine run with CR 5:1?. This is Maybe better for the Sparkplugs.
What CR do you guys run with your working engines.
« Last Edit: December 10, 2018, 05:12:51 PM by michelko »
Offline michelko
« Reply #290 on: December 10, 2018, 05:16:03 PM »
All parts ready machined, still have to cut the Center electrode to length and glue them together.
« Reply #291 on: December 10, 2018, 05:18:49 PM »
I have tended to design around 8-1, but this does not include the volume in the sparking plug or it's thread.
Offline michelko
« Reply #292 on: February 04, 2019, 08:54:45 AM »
Hi guys,
Little update on the Bugatti. I started to diassemble the engine.
I bought a cheap chinese pressure loosing tester to check for leaks.
Made an Adapter to fit the plug threads.
I found three leaking exhaust valves. Not realy bad but noticeable against the others.
All Inlet valves are leakfree :cheers:
The tool Shows realy low pressure loss on all cylinder (around 5 %).
But i think this tool is made for automotive engines with greater Dimensions so the numbers  it doesn´t mean anything.
I will then tear it apart and shorten the pistontops to reduce the cr.
Thinking so mutch about this problem i believe it is a combination between high compressionand high voltage from automotive coils.
So another step would be to reduce the high tension of the coils by shorten the dwelltime.
« Reply #293 on: February 04, 2019, 09:37:38 AM »
Hello Michael,
I am sure your methodical approach with tests and measurements will help you get the Bugatti to run sweetly. :ThumbsUp: :ThumbsUp:
Do you have drawings of the cam profile and cam timing? It may be helpful if we can help you check the overlap and open durations.
