Author Topic: Bugatti Typ 50 1/4 Scale model  (Read 74958 times)
Offline michelko
« on: February 02, 2017, 01:35:03 PM »
Hello,
like promised i start a build thread about my Bugatti Project.
It is based on the Pocher model of this Engine that i bought as Young man.
As far as i can remember i startetd with the planning in 2005 and made the first Chips in 2009.
The cas is made from Aluminium and all scratch build. No castings were used.
the only parts that were bought are the Rolerbearings, screws, Valvesprings an screws.
Offline michelko
Re: Bugatti Typ 50 1/4 Scale model
« Reply #1 on: February 02, 2017, 01:37:49 PM »
Here is the cylinderblock with intermediat plate an the bearing holders of the crankshaft. All parts are screwed together with M3 screws
« Reply #2 on: February 02, 2017, 01:44:23 PM »
Thank you Michael. I will be following this with great interest
Offline michelko
« Reply #3 on: February 03, 2017, 09:51:26 AM »
Hi guys,
here are some Pictures of the cam grinding machine. A friend of mine is also Building model engines and he lend me his machine.
You can see some blanks, some ready cams and some Details of the machine.
The template is from brass and is milled on a Rotary table.
Offline michelko
« Reply #4 on: February 03, 2017, 09:55:43 AM »
Here is the oilpan/housing. Ist made of Aluminium plates that were soldered together. Iam a Little unhappy with the result because the soldering has a different colour then the alu.
If i would build it again i will weld the case together instead of soldering.
Two wterjackets are machined at this state. six to go.
Offline michelko
« Reply #5 on: February 03, 2017, 10:02:28 AM »
next Pictures are from june 2012, we bought a haouse and this took some time that was missing for Building the Bugatti.
YOu can see my mill, it is cnc fitted and controlled by linuxcnc.
Here i am machining the cylinder head.
Offline michelko
« Reply #6 on: February 03, 2017, 10:06:39 AM »
some more machining on the head
Offline michelko
« Reply #7 on: February 03, 2017, 10:15:27 AM »
August 2012
cylinder head ready, Fitting the bearing blocks for the camshafts. They are made of brass.
pressed in liner for the cam Followers.
The Followers shown here are dummys, the real ones will have a pocket to fit a shim for lash adjustment.
Offline Nick_G
« Reply #8 on: February 03, 2017, 10:45:28 AM »
Awsomely awesome of awesomeness.  :ThumbsUp: :)
Nick
« Reply #9 on: February 03, 2017, 11:17:07 AM »
Oh keep them coming!    I like the camshaft and tappets work, can you show me the rest of the valve cage?
« Reply #10 on: February 03, 2017, 11:18:22 AM »
What Nick said. Awesome.
I'd never heard of a cam grinding machine. Time for a little googling.
Wonderful pictures!
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #11 on: February 03, 2017, 11:41:42 AM »
Beautiful work shown so for. Keep the pix coming.
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #12 on: February 03, 2017, 02:25:14 PM »
michelko,
That's amazing. I really like the way this build progresses.
Thank you for posting
ShopShoe
Offline ozzie46
« Reply #13 on: February 03, 2017, 02:46:23 PM »
Great stuff. What was the solder you used to solder the engine block together?
Offline michelko
« Reply #14 on: February 03, 2017, 05:57:01 PM »
Hi guys, thanks for the kind words.
I will post the pictures in chronoligical order. The engine itself is ready so far. Last two pieces that i have to build is the water pump and the blower. The blower will be a dummy. I am planning to fit the engine with a injection system like keith did.
The injector will be fittet in the blower housing.
At the moment i am working on the ignition system. Engine runs but not stable because of heavy noise in the rpm signal.
<a href="https://www.youtube.com/watch?v=ie0gc5bpFOY" target="_blank">http://www.youtube.com/watch?v=ie0gc5bpFOY</a>
