Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 92450 times)
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #690 on: January 06, 2019, 08:12:58 AM »
Big lads train set  :jumpingsmileys: :jumpingsmileys:
In the video you didn't make the sound Rich  :headscratch: You gotta make the sounds :stickpoke:
Usus est optimum magister
Offline Firebird
  • East Midlands UK
« Reply #691 on: January 06, 2019, 09:43:47 AM »
Hi
Thanks Kim  :ThumbsDown:
Ok then Jo  ::)
CHOOOOOOOOOOOO WOOOOOOOOOOOOOOO
CH CH CH CH CH CH CH CH CH  :embarassed:
Rich
« Reply #692 on: January 06, 2019, 09:59:58 AM »
 ;D
« Reply #693 on: January 06, 2019, 03:07:34 PM »
Almost time for the "compressed air run while you try to keep up with it to prevent it from running off the end of the bench!"  run!    :pinkelephant: :cartwheel: :whoohoo:
Offline Steve17
« Reply #694 on: January 06, 2019, 07:55:19 PM »
Brilliant  :pinkelephant: that alone would keep me going for hours. :cartwheel:
Steve.
Offline Firebird
  • East Midlands UK
« Reply #695 on: January 10, 2019, 07:31:08 PM »
Hi
Thanks Steamer and Steve  :ThumbsUp:
Some slow progress today.
Starting with some fine fettling to make sure the straps turn freely on the eccentrics
A trial assembly minus the wheel and crank.Some slight tweaking of the eccentric rods to re align them. I have marked them all with an engraver pen
Finally today refit the wheel and quarter the crank
Rich
« Reply #696 on: January 10, 2019, 07:42:18 PM »
Looking  :ThumbsUp: Rich!
Online Roger B
« Reply #697 on: January 10, 2019, 07:53:07 PM »
There's an awful lot of fiddley stuff involved  ::) but you are almost there  :ThumbsUp:  :ThumbsUp:  :wine1:
As Dave said can you catch it before the end of the test track  :)  :)
Offline Kim
« Reply #698 on: January 11, 2019, 06:11:04 AM »
Well done there, Rich!   :popcorn:
Offline Firebird
  • East Midlands UK
« Reply #699 on: January 11, 2019, 05:46:22 PM »
Hi
Thanks cnr6400, Roger and Kim  :ThumbsUp:
The modified eccentrics make adjustment so much easier. I had a go at setting the valves today but found one or two more places where things are just fouling, the fork on the expansion links for one which just prevents it turning freely so some more stripping and fettling ::)
But we are getting there  :)
Rich
Offline Firebird
  • East Midlands UK
« Reply #700 on: January 12, 2019, 06:41:42 PM »
Hi
Slightly out of order but made a pin for the reverse lever. Its a press fit in the stand
Took the expansion links to bits to fettle them and made a mess of one of them so had to make another ::)
Also I have removed the lock nut on the valve rod, it was very close to fouling the guide bush. You can see on the plans that he has specified a pin to hold it together (indicated by the arrow in pencil) which would have been almost impossible to fit in position which is why I went for a threaded rod. The threaded rod has now been fixed in position with loctite.
A bit of video
Rich
« Reply #701 on: January 12, 2019, 07:02:38 PM »
Nice smooth motion in the reverse linkage Rich!  :ThumbsUp: :popcorn:
Offline Steve17
« Reply #702 on: January 12, 2019, 07:49:11 PM »
Lovely motion, not long till running on air?
Steve.
Offline Kim
« Reply #703 on: January 13, 2019, 12:00:37 AM »
Very nice Rich!  It's fun to see things moving - and such smooth operation!
Thanks for the video.
Offline Firebird
  • East Midlands UK
« Reply #704 on: January 13, 2019, 11:02:53 AM »
Hi
Thanks cnr6400, Steve and Kim  :ThumbsUp:
A question  :thinking:
In the text Martin evans reccomends Shell Vitrea oil for lubricating the moving parts but he doesn't mention which grade??
A quick google shows grades from 27 upto 320 but bearing in mind the article was published in 1980 the oil probably doesn't exist now.
What type/grade of oil should I use
Rich
