Author Topic: Freelance Inline Twin  (Read 36667 times)
  • Raleigh,NC. USA
    • Lauson small engines
Re: Freelance Inline Twin
« Reply #210 on: December 06, 2018, 11:50:29 PM »
How have I missed this thread till now  :-[
You've built a little Jem Yogi  :cheers:
« Reply #211 on: December 07, 2018, 12:09:57 AM »
A very class act Yogi. Beautiful engine.---Brian
Offline kuhncw
« Reply #212 on: January 21, 2019, 02:06:43 AM »
Yogi, where did you buy the 4 X 8 X 2 lip seals for your coolant pump?
Thanks.
Chuck
Offline scc
  • Lancashire, UK
« Reply #213 on: January 21, 2019, 10:04:29 AM »
An extremely nice engine Yogi,  Good job!     Terry
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #214 on: January 21, 2019, 12:51:23 PM »
Thank you guys for the compliments! It's very much appreciated.  :cheers: :cheers: :cheers:
Chuck, I found the lip seals at Grainger.
https://www.grainger.com/product/DDS-Single-Lip-Rotary-Shaft-Seal-52VZ39
Yogi
Offline kuhncw
« Reply #215 on: January 21, 2019, 03:48:05 PM »
Yogi,
Thanks for the source for the 4mm seal.
Chuck
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #216 on: March 13, 2019, 08:40:31 PM »
Alright, I have another part to add to the engine, as I still work on the cooling system.
The fan is made from .040" 3003 aluminum sheet. I used CA glue and masking tape to secure the sheet to a plate. The use of masking tape seems to be popular by a number of YouTube machinist, so I figured I would give it a try. It worked very well. To release, I warmed up the parts until the bond let go.
The fan blade after deburring:
To press the radius into the blades, I 3d printed a die with the required shape. This was an experiment, and it worked flawless. I'm certain this would work on even thicker material.
The last part was to twist the blades. For this, I used the bending die again, to gripped the blade firmly, while using a protractor to twist each blade the same amount.
The finished fan:
The fan installed on the engine:
Thanks for following along, and stay tuned for more.
Yogi
« Reply #217 on: March 13, 2019, 09:09:55 PM »
Great work on the fan Yogi. Liked the 3D printed tooling! Looks like the engine's almost ready to bark.
  • S°ften - Denmark
« Reply #218 on: March 13, 2019, 10:11:48 PM »
Nice use of modern tools - CNC + 3D printing => great result  :ThumbsUp:
« Reply #219 on: March 13, 2019, 11:24:54 PM »
Hello Yogi,
That engine is so beautiful and a neat job on making the fan.
Have a great day,
Offline 90LX_Notch
    • YouTube Channel
« Reply #220 on: March 13, 2019, 11:30:51 PM »
Nice!
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline toolznthings
  • Kent,Ohio
« Reply #221 on: March 14, 2019, 01:37:06 AM »
Genius work !! Looks fantastic  :ThumbsUp:
Thanks for the visit !
Brian
« Reply #222 on: March 14, 2019, 01:50:39 AM »
Yogi,
The engine looks great, looks like one more reason to get a 3D printer. That fan looks really good.
Offline Zephyrin
  • near Paris, France
« Reply #223 on: March 14, 2019, 08:27:48 AM »
Wow, beautiful job with this engine.
I like very much this modern way to build model engine, up to date technical and engineering, immaculate results...
« Reply #224 on: March 17, 2019, 04:58:10 PM »
Hi Yogi, I like the fan.
