Author Topic: Keats Angle Plate  (Read 23024 times)
Bogstandard
Keats Angle Plate
« on: September 02, 2012, 10:05:06 AM »
This post is made up of two separate posts that I have shown in the past, so if some bits are repeated, just put it down to my inexperience of making up posts.
Because I have trouble using a four jaw independent chuck, I am now going to introduce you machinists to one of the most underrated bits of kit you can buy. Some of you will have heard of one, some might have even seen one, but most have no idea how versatile this lump of metal can be. Another version, from the US, is called a Rike vice, but it is not quite as versatile, unless you modify it a lot.
Before I go on, just picture the scenario, making a few model engines, all with the same cylinder with an offset bore. What a PITA setting up the four jaw every time just to bore the thru holes. Say you have got a long throw crank to make, and your four jaw can't give you enough offset, what do you do?
I will now show you the infamous bit of kit.
PART 1
THE KEATS ANGLE PLATE.
I will just explain a little about the two castings. The big one wiv the big 'oles is ground with the baseplate and v-groove at perfect right angles. The smaller gripper casting is also ground up square, but is slightly narrower top to bottom than the main casting, this ensures that the main casting is used as the datum faces and the gripper plays no other role than clamping the part.
This first pic shows the plate set up for holding large bits, if you used longer bolts, it could hold up to 3.5" diameter.
Here it is with the grip plate turned around for holding small stuff.
Now for all you lathe owners, this bit on your shelf or in the cupboard, covered with 1/2" of crap piled up on it is actually called a faceplate, and yes, it does fit onto your spindle nose, and yes again, it does have a use other than gathering dust.
This one is mine, and if you look at the red markings on it, it is about to be drilled, then the Keats angle plate will be bolted to it, and it will transform your four jaw PITA work into something a little more civilised and less painful. If your faceplate is smaller, you might even find that the holes line up with the originals.
As you can see, I haven't drilled it yet (and won't do for a few more days yet, but I have put the plate on to show the normal operating range of your 4 jaw. So how is it better than the 4 jaw?
Once you have set up the initial job in the V's, and gently tapped the plate into the correct position, then done a white knuckle job on the holding bolts, you can just slacken the gripper and drop another piece in, tighten up and machine it exactly the same as the first. If you used a 4 jaw, once you slacken one of the jaws, you are forced to set the next piece up, just like the first one you did.
I am sure I know which one I prefer to use.
Here it is shown with a lot more offset if needed.
And if you are really brave (or stupid) and have enough clearance for a big swing, rather large offsets can be obtained.
I must add now, with any faceplate work, using a large offset you should really balance things out by clamping a weight, roughly the weight of the keats plate and workpiece directly opposite on the faceplate, just to balance things out. Otherwise things start to get out of hand very quickly.
Here is a shot of it holding a bit of 1" brass.
But there is even more talent this lump of ground up cast iron can show you, look at the next pic.
It doubles up as a very versatile clamp for holding things truly vertical on the mill.
I am not saying this item is the be all and end all to your offset machining, but it sure goes a long way, at about 30 squid incl P&P in the UK it has to be a good investment.
PART 2
Just tinkering about the shop, I decided to finish off a little job I should have done ages ago.
Nothing too strenuous or mind numbing, just a few 8mm holes drilled and tapped in a logical pattern into my faceplate.
By doing this, it allowed me to bolt on my Keats angle plate.
I have mentioned these before, and IMHO they are a lot easier to set up than a four jaw. Maybe not as versatile as a 4 jaw independent with regards to size holding, but if you are making more than one of the same thing, it can save you hours of setting up.
Once you have tapped the plate into it's final resting place for doing the job, and tweaked it up tight onto the faceplate, if you need to do another of the same thing, just slacken the two clamp screws, put in a new piece part, and away you go. With a four jaw, your have to reset the jaws every time you slacken the jaws off.
Holding a bit of square bar.
Then a bit of small round.
My four jaw is massive and too heavy for me to lift safely, and until I get my new donated chuck mounted up, this will do me just fine.
If you can fit one of these onto your faceplate, for the price, it is silly not to have one.
http://rdgtools.co.uk/acatalog/Keats_Angleplates.html
I didn't mention this time that they can be bolted or clamped to your mill table to hold things perfectly vertical for milling, or can also be used on a surface grinder or shaper for doing the same thing. Or even on your surface plate for marking up. Can't think of anything else just yet, but I am sure there are a lot more uses.
It is a real universal tool.
« Last Edit: September 02, 2012, 04:55:21 PM by Bogstandard »
Re: Keats Angle Plate
« Reply #1 on: September 02, 2012, 11:38:01 AM »
Good one Bogs!   Need to get me one for the SB.....
« Reply #2 on: September 02, 2012, 01:43:31 PM »
Thanks for the write up John,  I need to get one myself. That will save me some setups time for sure.
« Reply #3 on: September 02, 2012, 04:40:13 PM »
OK John....pulled the trigger this morning......It'll be here eventually.
Bogstandard
« Reply #4 on: September 02, 2012, 05:00:53 PM »
Dave,
I don't think you will regret it at all.
I don't know how much the carriage is to the US, but here in the UK, that price includes the carriage, so at that price, it is not worth trying to make such a versatile bit of tooling yourself.
Maybe the US lads could follow the Rike vice route if the cost is too high. Does the same sort of thing, but not as versatile.
http://littlemachineshop.com/products/product_view.php?ProductID=2304
« Reply #5 on: September 02, 2012, 05:23:36 PM »
True Bogs....but I've got enough tooling to make for the SB as it is.....sometimes I just want to buy it.
« Reply #6 on: September 02, 2012, 05:58:43 PM »
John I have built the Rike vise. It is useful for certain applications, but cumbersome. There is a lot of metal removable to make this vise. I used the Rike vice to bore the cylinder of my Epicyclic engine. But I really want to give the Keats plate a try.
« Reply #7 on: September 02, 2012, 06:05:31 PM »
I know the shipping will be tough...but I've heard and seen enough about the Keats that I'm just going for it...besides...I won't need another one for 40-50 years......after that...who cares what the shipping was.... ::)
Offline sshire
    • LS Editions
« Reply #8 on: September 02, 2012, 06:18:33 PM »
This will be very useful. I was going to make it but I'd rather build engines.
Just got my PayPal receipt. Total with shipping was 50GBP ($80). About 1.5 bottles of single malt but this will last longer
Best
Stan
« Last Edit: September 02, 2012, 07:37:21 PM by sshire »
Best,
Stan
Bogstandard
« Reply #9 on: September 02, 2012, 06:53:01 PM »
If someone has a copy of magazine #3 of Model Engineers Workshop (winter 1990) then there is a very good build shown of it, and if someone can cast cast iron, then it could easily be made from that article, as all critical dimensions are shown.
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #10 on: September 02, 2012, 10:03:14 PM »
The other option is to fabricate one - it was Len Mason (I think) who gave a good description of doing this in one of his books.
I have a little micro version here that I made to go on the 3" faceplate I made.
Offline IanR
  • Derby, UK
« Reply #11 on: September 05, 2012, 09:59:11 AM »
It was, in "Using The Small Lathe", published in 1963.
The gadget in the original post is not a Keats. This is a Keats.
« Reply #12 on: September 05, 2012, 10:04:18 AM »
Thanks for that Ian!
Offline sshire
    • LS Editions
« Reply #13 on: September 05, 2012, 08:46:01 PM »
This appeared in the mail today.
I ordered it 3 days ago with standard shipping. I don't get stuff that fast from McMaster and they are just 80 miles from here (Philadelphia, PA)
Drilling of faceplate will commence as soon as I finish the Epicyclic Engine flywheel.
Best
Stan
Best,
Stan
« Reply #14 on: September 05, 2012, 10:27:56 PM »
Stan you guy made me break down and order one, and by the way how is the Epicyclic engine coming alone. Are you doing a built log?
