Author Topic: Another way to stop chatter at the lathe ....  (Read 1638 times)
toolznthings
« on: April 10, 2016, 05:12:51 PM »
Stopping chatter on lathe turnings can be a real problem, especially on long small diameters and even larger turnings.  When all else fails with speed, feed, and tool radius the following solution usually works.
I have made several small hand held lead " hammers " about three inches long and one inch plus in diameter. Handy for numerous uses around the shop.
Pictured is how I would use the lead when turning. ( an example, no chips  ;D  ) I would use the smallest tool nose radius practical, carbide or HSS, adjust my RPM and feed and let the lead slug ride on the work piece at the point where the tool is cutting. It is not necessary to apply heavy force as to effect the cutting diameter, but enough contact to absorb the vibrations from the cut. Follow along the cut as needed. A drop of oil where the lead rides also helps.
Doesn't always work, but has saved the day more than once when all else has failed.
Offline pgp001
  • West Yorkshire - UK
Re: Another way to stop chatter at the lathe ....
« Reply #1 on: April 10, 2016, 05:43:40 PM »
Offline cheepo45
« Reply #2 on: April 10, 2016, 06:18:33 PM »
Plastic dead blow hammers held lightly on the part being turned also work well.
 cheepo45
