Author Topic: Straight line steam engine  (Read 48931 times)
Offline simplyloco
  • Firstly the Stuart Beam, now it's the Big Time!
Re: Straight line steam engine
« Reply #270 on: March 10, 2019, 09:54:17 PM »
Wonderful attention to detail! :praise2:
Offline rarach22
« Reply #271 on: March 23, 2019, 05:59:33 PM »
Steam test
Offline rarach22
« Reply #272 on: March 24, 2019, 08:17:59 PM »
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #273 on: March 24, 2019, 08:34:30 PM »
What a great model Pavel, you gotta be proud of that  :)
« Reply #274 on: March 24, 2019, 09:27:11 PM »
Beautiful Pavel
Is that singing noise the same typical noise a generator makes [the making and collapsing of the electrical fields] or the leather belt sequel under the tension?
Either way again  :facepalm:
Derek
Offline rarach22
« Reply #275 on: March 24, 2019, 09:50:17 PM »
Beautiful Pavel
Derek
Hi Derek, You're right, it's a generator....I was surprised by the sound and I like it ...Pavel
Online Dave Otto
« Reply #276 on: March 25, 2019, 12:05:24 AM »
Wow what an amazing model/s Pavel!
It is simply stunning.
« Reply #277 on: March 25, 2019, 03:02:37 AM »
Hi Pavel, very impressive. You should be very proud of it.
Offline MJM460
« Reply #278 on: March 25, 2019, 06:22:51 AM »
Hi Pavel, a beautiful model and amazing workmanship down to the smallest details.  It has been most interesting to follow along.
Offline gary.a.ayres
« Reply #279 on: March 25, 2019, 06:54:01 AM »
Gorgeous!
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #280 on: March 25, 2019, 12:36:21 PM »
Pavel,
That's amazing! I am also surprized by the generator noise and like it.
Incfedible attention to detail. Everything is so precise and well done.
I have been following your posts on this and I knew if would be worth the wait.
Thank Your for posting,
ShopShoe
« Reply #281 on: March 25, 2019, 12:53:15 PM »
The whole thing is just amazing Pavel, from the boiler to the engine itself, to the steam pump and generator. What a fine example of model engineering at it's best!!  Well done  :ThumbsUp: :ThumbsUp:
Offline rarach22
« Reply #282 on: June 23, 2019, 05:57:17 PM »
Changing steam lubricators, those old cracked glass, is good to use glass with electronic cigarettes
« Reply #283 on: June 23, 2019, 06:45:49 PM »
Hi Pavel,
good to see that you have found a solution and improvement for your lubrication glasses.
It was a real pleasure to see your engines, boilers an the entire arrangements at this show in Austria last weekend.
I admire your attention for all the small details.
Offline rarach22
« Reply #284 on: June 23, 2019, 08:23:29 PM »
Thank you,
The steam lubricators will hopefully work. As for the details, I can still learn from you. There's still a lot to learn ..... Thank you for coming last weekend.
