Author Topic: Can banding material be milled?  (Read 1210 times)
« on: February 28, 2015, 05:33:40 PM »
Can the banding metal be milled? I have some clips I need to make that will require a small slot.
Whiskey
Re: Can banding material be milled?
« Reply #1 on: February 28, 2015, 05:52:34 PM »
Do a test... Clamp a piece tightly between two pieces of aluminum (or, gasp, wood) and try to cut a slot.
Personally, I think a Dremel with a grinding/cutoff wheel might be a better choice, depending, of course, on the geometry of the slot.
« Reply #2 on: February 28, 2015, 10:36:06 PM »
I made leaf springs for the loco using spring steel that's thicker than banding straps.  Cut slots quite easily with carbide endmill.
