Author Topic: M.E.M. Corliss Question  (Read 3467 times)
Offline wagnmkr
  • Lindsay, Ontario, Canada
« on: October 28, 2014, 07:15:10 PM »
Hello All,
I am assembling materials and ideas for my version of the M.E.M. Corliss.
I would like to put a tile surface on the base to hide the aluminum plate I will use for that. I am not sure if that would have been done in real practice or not. Also, I have no idea of the scale of the engine so I am not sure of what size tile to make.
I have used this method in a couple of doll houses with good results and I thought it would look good in this case.
Any ideas?
Cheers,
Tom
Re: M.E.M. Corliss Question
« Reply #1 on: October 28, 2014, 09:03:58 PM »
Hi Tom.
Like you I would like to use simulated floor tiles for the aluminum base.  I was thinking of using black and white tiles in a chequered pattern.  I am confident it will look good on the Corliss because I have seen other steam models that use this pattern and they look really good.  The problem is how to do it.  So I would also be interested in the replies that you get.
I have been told that a commercial printer shop can actually print the tile pattern directly on an aluminum surface but have to investigate this idea further.  Another possibility I am toying with is vinyl tiles that you glue to the base.  These tiles can be found in doll house shops and can easily be cut to ones desired size.
Offline wagnmkr
« Reply #2 on: October 28, 2014, 09:48:20 PM »
Vince, I used some of the tiles available on the net in the kitchen of a doll house I built a long time ago. They worked fine.
I have also used self stick vinyl tiles from Home Depot. Some I cut to size on a table saw, and some I just scored with a small "v" shaped word carving tool. I am also thinking of making the tiles from Sculpey (oven baked modelling clay). I will see what sizes I get.
Cheers,
Tom
« Reply #3 on: October 29, 2014, 05:16:00 AM »
Hi Tom and Vince, I can give a link to the Europeen doll house scene only.
http://www.eurominis.nl/eurominis-gelamineerd-tegelvel-reliefdruk-2846512.html
This Dutch company sells different designs of "printed" tiles.
Printed card board and sealed.
This is an example at a steam engine model.
http://www.dampfundmehr.de/HP/bergbau/P1070856.jpg
« Reply #4 on: October 29, 2014, 08:01:17 AM »
Its quite easy to do with a couple of cans of spray paint and a sheet of self adhesive vinyl or masking film.
First prep and spray the whole base in the lighter of the two colours
Once fully dried place the vinyl over the top, mark out a grid to suit the tile size you want to use (10mm on this one) and cut in both directions with a scalple. Peel off alternate squares of vinyl
Once you have removed all the squares spray with the darker colour, after it has dried peel off the remaining squares to reveal the lighter colour below.
Or black on white
Offline wagnmkr
« Reply #5 on: October 29, 2014, 10:34:23 AM »
Achim, thank you for those links. I am going to try and contact those folks.
Jason, Thanks for you pics. Given that the base of the Corliss is around 17" long, what size squares would you recommend?
Nice job on your bases. The engines are not too shabby either :NotWorthy:
Tom
« Reply #6 on: October 29, 2014, 12:01:25 PM »
That beam engine base is about 16" with a 7" flywheel, 10mm squares.
Can't remember what the approx scale of the MEM one is, we did discuss it and the flywheel proportions early on but I should think 8-12mm or 5/16 - 1/2" would suit
Offline wagnmkr
« Reply #7 on: October 29, 2014, 12:31:26 PM »
Thanks Jason. I just did some rough calculations and came up with around the 1/2" mark as well, so I will likely go with that. A long way to go before I get to that though.
Tom
